Headlamp Washer traumas
Posted: Wed Dec 14, 2005 6:21 pm
by Monteey
Hi guys and gals
Well had my gti for just over 2 weeks now and hugely impressed by it, i love it!
Only problem thats cropped up is the headlight washers dont seem to want to pop up and work anymore. I know they only work when the lights are on and i can hear the pump running then stopping after a second or so, but they arent popping up at all on either side.
Any ideas, do they stop working when the fluid level is low, i assume they feed off the main windscreen wash tank
Thanks for any pointers
Posted: Wed Dec 14, 2005 7:05 pm
by Josh_PoloGTi
IIRC, when your washer bottle gets low, they stop working.
Try filling the tank up to the brim, then trying them again.
Posted: Thu Dec 15, 2005 4:06 pm
by ModifiedMadness
Yeah that's right Josh, that happened with mine, check the level in your washer bottle, if you have under a litre in it they don't work.
I was kindly informed of that when it happened with mine.
Hope that helps.
Posted: Fri Dec 16, 2005 12:47 am
by inder
Also check to see if the water pipes are attached and so its not pissing on the floor.
Most likely the reasons posted above though!
Posted: Fri Dec 16, 2005 1:38 pm
by Monteey
Yup as suspected the bottle was almost empty, didnt notice it as i was looking in the dark doh!
Anyway crisis over, all filled up and washers working fine now :D
Thanks for the tips
