poorly GTi
metalblue
poorly GTi
Post by metalblue »
Had been stuck in traffic for about 30 minutes, crawling along my GTi started making a noise from underneath the front like something was stuck in the wheels or a flat. Got out checked nothing obvious so carried on driving.
Cleared traffic got out on the motorway no strange sounds (although perhaps a bit more noise but not sure) and was driving ok (although did notice my temp gauge dropped to 70 before going back to the middle)
Left motorway and came to a series of roundabouts, traffic lights etc, gearbox seemed a bit stiff but managed to change gears no problem, car did seem a bit noisey and not pulling as well as normal. After a while the speedo packed up and I came to another roundabout where no gear could be selected, eventually got it into gear with a horrible smell coming from underneath, as my first thought was clutch and I was near local tyre/clutch/exhaust place made a crawl for that but although I could select all gears if in fouth the engine would just rev, also the petrol gauge is giving random readings now.
I'm thinking the local tyre/exhaust place isn't going to be able to assist but would be grateful of any clues as I suspect this is going to VW and knowing what a clued up bunch you are on here I want half an idea of possible causes ahead of the "quote"
cheers all :cry:
metalblue
Post by metalblue »
it's the gearbox. just been quoted between £575 (if barings) and £700 (worst case) which includes new clutch so not too bad
neilw
Post by neilw »
:x Thats annoying! hope you get it sorted alrite tho! See if you can get the sacs clutch in there instead of the standard one when theychange it?
