temprature gauge faulty ? who knows.
Posted: Sun Jan 22, 2006 10:18 am
by plr
I have a Mark 1 1987 polo and the temprature gauge needle has stopped working but the red light is flashing on and off constantly and the car rumbles and stalls sometimes at the traffic lights. No other sign of over heating though.
I have checked the water level which is fine and cannot see any other problems. Any ideas what this could be ?
Thanks a lot, appreciated the help.
Paul.
Posted: Mon Jan 23, 2006 12:11 pm
by GroovyCarrot
Your temperature sensor has packed in. You'll need to replace the black one, you can pick one up for a couple of quid at gsf, and it only takes a few minutes to fit. The sensors are on the front of the thermostat housing, just look for two plugs going into the housing.
Re: temperature gauge faulty? No the sensor
Posted: Mon Jun 01, 2009 6:33 pm
by mervyncp
Appologies for re opening an old post, but my son has an '87 1043cc Polo as his first car.
The temperature gauge reads full hot all the time and the red light is flashing, so I suspect the sensor needs changing.
You mention 2 sensors attached to the thermostat housing.
One is the temp gauge sensor...
What is the other one?
Which is which?
Mervyn
Re: temprature gauge faulty ? who knows.
Posted: Mon Jun 01, 2009 11:05 pm
by alexperkins
One is for the gauges, the other is for the ECU ;)
Re: temperature gauge faulty ? who knows.
Posted: Wed Jun 03, 2009 11:07 am
by mervyncp
alexperkins wrote:One is for the gauges, the other is for the ECU ;)
So are they identical parts then? and which is which?
Posted: Wed Jun 03, 2009 1:12 pm
by alexperkins
They are different parts. One is blue one is black :)
Blue is ECU it think black is gauges
