Headlight Jets
Posted: Wed Jan 25, 2006 9:16 am
by benny oopz
Hi all.
This is my 1st post, but must say great site with lots of useful info and great posts by all you guys.
Anyway, when I spray my windscreen, my washer jets will sometimes come on and sometimes ........ not.
I thought this had something to do with when ice was indicated in the dash, but they sometimes come one when it's not.
Does anyone know when they're triggered or if I have a problem?
(This is probably in black and white in my manual, so excuse my laziness).
Posted: Wed Jan 25, 2006 9:33 am
by neilw
They only come on when the headlights are switched on, and you spray the windscreen. Welcome to the forum!
Posted: Wed Jan 25, 2006 9:34 am
by ModifiedMadness
If you're on about the headlight washer's as the title says, the only time they spray is when the headlights are on, if they don't spray and you have got the headlights on, then check your water level.
If it's the windscreen washers, again check your water level, if that's ok then I don't know mate.
Hope that answers your question.
Posted: Wed Jan 25, 2006 10:13 am
by benny oopz
Yeah, they don't seem to always spray when the lights are on.
I'll check my water level, but it should be pretty healthy.
Thanks guys.
Posted: Wed Jan 25, 2006 12:35 pm
by inder
You have an ice symbol? :oops: what do you mean? thanks :)
Posted: Wed Jan 25, 2006 1:20 pm
by neilw
Mine has an ice sysbol on the outside tempreture gauge, you get a little * when it get down to about 2degree.
Posted: Wed Jan 25, 2006 1:32 pm
by PieGTi
The headlight washers will stop working
when the washer fluid level falls below a certain level,
however the windscreen will continue to work until empty.
I find that my fluid level drops dramatically with the headlight washers.
Hope this helps.
Posted: Wed Jan 25, 2006 2:30 pm
by neilw
I never knew that! clever stuff
Posted: Wed Jan 25, 2006 5:27 pm
by inder
neilw wrote:Mine has an ice sysbol on the outside tempreture gauge, you get a little * when it get down to about 2degree.
ahh I see - I've not got a GTi, so was not sure what he meant :)
any chance of a pic of the temp gauge on the dash? cheers m8!
Posted: Thu Jan 26, 2006 10:58 am
by neilw
Ooo I found a pic!
Must be old, my car says 35000miles its nearly 50000 now
Posted: Thu Jan 26, 2006 7:29 pm
by inder
Excellent, cheers m8
hehe, yep - looked like you were due for a service too - light is on :D
Posted: Thu Jan 26, 2006 7:47 pm
by ModifiedMadness
Is it? I thought he just had the ignition on?
Posted: Thu Jan 26, 2006 11:00 pm
by inder
ModifiedMadness wrote:Is it? I thought he just had the ignition on?
Say's INSP where the millage would be :p
The ESP light could be showing a fault or like you say, during ignition and would be going out
Posted: Thu Jan 26, 2006 11:09 pm
by ModifiedMadness
Well spotted, I didn't see the INSP :lol:
Posted: Fri Jan 27, 2006 11:09 am
by neilw
ESP goes away once you start the car.
