Door Bump Strips
Posted: Fri Sep 12, 2003 12:10 am
by Hayes-polo
Do the bump strips on the doors of polo's have guide studs that fit into holes in the door or are they just stuck on with the foam strips? I wanna remove them from my other halfs car so it looks more colour coded. If I can get away with just removing them rather than painting them I will! Don't wanna go down the filling the door road. Any one done this?
Posted: Fri Sep 12, 2003 12:50 am
by jakethesnake
Hi
On the mkIV or 6N they are simply stuck on.
On the mkV or 6N2 they are fixed through holes in the door plus adhesive.
If you have a mkIV simply heat the strips up with a heat gun or hairdryer and slowly pull them off.
Clean up the sticky mess left on the door and then give it a good wax.
Job done !. It looks miles better
Posted: Sat Oct 18, 2003 7:36 pm
by TONY
ive removed both the side strips and the rear badges. looks much better
look at the standardness! oh the horror!
Posted: Thu Oct 23, 2003 6:55 pm
by LOW PHAT SPREAD
When I removed mine, it left a mark in the laquer of the paint, n had to get both sides painted, which I was doing anyway so wasnt too bad.
Posted: Thu Sep 15, 2005 10:11 am
by henry01
mine just pulled off then i used t-cut to remove any marks that they left.
looks mint now
