angel eye pics
Posted: Wed Feb 01, 2006 8:49 pm
by OMEGASUPR3ME
hi guys n gals was just wonderin if one of you who have angel eyes can take some pics of what u have to dremel away, i'll prob be able to guess when i try n fit them myself but just incase. mine should be coming soonish :D
Posted: Thu Feb 02, 2006 6:43 pm
by RR Livi
Hey this is what they look like :wink:
The wiring is quite easy to do so it should not be a problem.
Does your car have height adjustment?
Posted: Thu Feb 02, 2006 7:11 pm
by mysteryboy
u dont have to go far to find some1 with them on...
http://www.tigerstyle.co.uk/poloforum/v ... hp?t=19008
Posted: Fri Feb 03, 2006 2:11 am
by OMEGASUPR3ME
i meant under the bonnet :P so i can see which bit to grind away
Posted: Fri Feb 03, 2006 12:18 pm
by RR Livi
the modification instuctions tells you how much you need to grind away, just take care when cutting though with the wires that run around the fiberglass frontpanel section
ill try and get pics up tonight of the wiring, but you need to modify the wiring if you dont have height adjustment headlights
