Page 1 of 2
Rear wiper problems - HELP
Posted: Thu Feb 23, 2006 1:13 pm
by owenjt
My rear wiper is constantly being temperamental, and decides to work sometimes but not others! Anyone know why this might be?
Posted: Thu Feb 23, 2006 1:39 pm
by andrea
My wiper is doing the same thing.
My other half is looking at it over the weekend for me, so when I find out what is wrong with mine i'll let you know xxx
Posted: Thu Feb 23, 2006 4:07 pm
by owenjt
Thanks - it's getting really annoying!
Posted: Thu Feb 23, 2006 9:18 pm
by kenny15
my was sticking when it was work , so when a got a second hand one today for £25 for thea breaker and it sorted
Posted: Thu Feb 23, 2006 10:34 pm
by Robbo
Mines on the fritz as well. It usually works within a couple of minutes of starting up and then stops working.
Posted: Thu Feb 23, 2006 10:40 pm
by moynas
Sounds like you have a bad connection on the wiper motor?
Maybe a bit of water has got in and started to make it fail?
Take the internal panel off the boot and check all connections, unclip clean with dry brush etc then replace and give it a go!
Posted: Mon Feb 27, 2006 10:28 pm
by owenjt
moynas wrote:Take the internal panel off the boot and check all connections, unclip clean with dry brush etc then replace and give it a go!
Will try this and see what's what. I do seem to be using more water than i think i should be but i've never noticed any damp around the boot area.
Posted: Tue Feb 28, 2006 8:36 pm
by andyg
Well the water jet on the rear wiper is notorious for not working on 6n2's and 9ns. The pipe pops off and leaks water into the bootlock mechanism and/or the carpet. But what you guys say sounds like the actual wiper itself?
If so could be a faulty switch on the wiper stalk.
Posted: Tue Feb 28, 2006 9:44 pm
by PhilGTi
Best idea for this problem is to remove it :D Looks good and doesnt give you any s**t!
Posted: Tue Feb 28, 2006 10:09 pm
by Si_GTi
PhilGTi wrote:Best idea for this problem is to remove it :D Looks good and doesnt give you any ****!
Top plan. I'm keeping mine for a bit longer though (until the clocks go back/forward* anyway) but will shave it off for the summer 8)
* for the life of me I can never remember which way they go!
Posted: Tue Feb 28, 2006 10:10 pm
by PhilGTi
Planning ahead is a skill ive still not aquired :D
Posted: Thu Mar 02, 2006 3:22 pm
by Robbo
I whipped off the trim last weekend and had a good look around. All of the connections are solid and uncorroded and the pipe isn't leaking. Since putting the cover back on, the wiper's been working the whole time.
I think it's just doing it to spite me :)
Posted: Thu Mar 02, 2006 5:17 pm
by vr6south
Robbo wrote:I whipped off the trim last weekend and had a good look around. All of the connections are solid and uncorroded and the pipe isn't leaking. Since putting the cover back on, the wiper's been working the whole time.
I had the same problem. Took the cover off, gave it a damn good looking at, and it's been OK for nearly a year. To think, I could have paid VW £75 an hour to do the same.
Posted: Sat Mar 11, 2006 1:39 pm
by owenjt
Ok so i took the trim off and there's no damp or water damage and everything looks OK. Unfortunately however it still doesn't work properly! Think i might take it to VW and get them to look at it and the rattling passenger door as the same time (only rattled since they fixed it!).
See what they say but i bet it's not covered under warranty either!
Posted: Thu Apr 06, 2006 5:11 pm
by owenjt
Ok so vw now telling me i need a new wiper motor which they charge £140 without labour (no surprise there then).
I presume if i can find a mk5 polo at the scrapyard i can take one off that, or is there anywhere else i can get one cheap? Also are they easy to fit?
