Full Alarm/Remote starter and total closure system on offer
Posted: Tue Feb 28, 2006 10:42 pm
by steph722
This isn't exactly a group buy, its a perminant offer I have managed to arrange for everybody. If this is in the wrong section then sorry, I wasn't quite sure where to put it.
Falcon Predator EVO4+ Car Alarm System with add-on Falcon RS300 Remote Starter System and Transponder Bypass Module
Comes with one LCD Pager Remote... Image
...and one Carbon Fibre Effect Remote
With all the features of the popular Evo4 the EVO4+ also boasts a fantastic LCD pager remote control. As well as performing all the normal remote functions, the LCD pager remote will alert you audibly if you alarm goes off and the built in LCD will indicate which part of the alarm was triggered.
Alarm Features
  • Modular alarm system for the best in security & reliability
  • Includes Loud 118dB two tone siren
  • Anti-scanning Code learning Remote Control System
  • One LCD pager remote control and one Four button long range remote controls with carbon fibre effect finish
  • Includes dual stage shock sensor, other detectors available
  • Supports up to 4 remote control's
  • Remote Engine Start with auto start for battery charging and heating
  • Turbo Timer
  • Silent Arm/Disarm Option
  • Panic feature from remote control
  • Universal Central Locking Control
  • Total Closure Facility (for vehicles with this facility)
  • Auxilliary output controlled from remote control (eg. for control of boot release)
  • Engine immobiliser
  • Last Door Arming/Passive Arming sets the alarm automatically (optional)
  • Passive Locking locks the door automatically (optional)
  • Flashing Hazard Lights on arm/disarm/activation
  • Temporary shock sensor bypass from remote control
  • Valet mode to disable alarm functions (from remote control)
  • Full Automatic Anti Hijack or from remote control
  • Auto re-arm prevents accidental disarming (optional)
  • Ignition lock/unlock automatically locks/unlocks doors when ignition is turned on/off (optional)
  • Smart chirps intrusion indication
  • Smart dashboard status LED
  • Arm condition memory
  • Defective Zone Bypass prevents false alarms
  • Car Finder feature
  • Secure Emergency Over-ride facility
  • Bonnet protection by supplied switch
  • Door protection where switches fitted
  • Boot protection where switches fitted
*** INCLUDES ***
Falcon RS300 Remote Starter System rrp £74.99
Remote engine starter system, allows the vehicles engine to be started by remote control when used in conjunction with an alarm system with a auxilliary output (such as the Falcon Predator).
Adjustable Cranking & engine running time
Switchable for Vacuum/Tacho/Smart sensing
Remote Start feature is not compatible with SAABs that require the car to be left in reverse gear before removing the ignition key.
*** INCLUDES ***
Transponder Bypass Module rrp £39.99
Bypasses factory fit engine immobilisers where a transponder chip is embedded in the ignition key.
The key is placed inside the bypass module which is then located in a secure place under the dashboard. A lead then runs from this and loops around the ignition barrel. This keeps the immobiliser turned off allowing the used of remote starters etc.
*** INCLUDES ***
Window closure unit for 4 windows. Negative input, Universal output.
Compatible with all Falcon alarms
or
Window closure unit for 2 windows. Negative input, Universal output.
Compatible with all Falcon alarms.
This window closure module works with your alarm system to close your electric windows automatically when you arm your alarm. No need to close your windows when parking, just turn the car alarm on and the windows will close automatically.
Window Closure Module for any car alarm with central locking
Will Close 4 Electric Windows (one by one)
Negative or positive trigger input
Universal Output
Autosenses when the window is fully closed
Safety System stops windows if you put pressure on the window during operation
For the Evo4+ with the remote start kit and the total closure prices are...
2 window car. £199.99 enter voucher code Ev04-2
http://cms.purecarsound.co.uk/modules.p ... cts_id=805
4 window car. £219.99 enter voucher code Ev04-4
http://cms.purecarsound.co.uk/modules.p ... cts_id=806
Pure Car Sound is the UK re-seller for a wide range of I.C.E products to suit all budgets and requirements. Offering names famous the world over for quality, reliability and all out performance.
Recommended trader on...
www.corsa-c.co.uk / www.corsa-b.co.uk / www.purevaux.co.uk
www.fiatforum.com / www.corsa2corsa.co.uk / www.axownersclub.com
