UK-POLOS.NET - THE VW Polo Forum • Engine sound :S
Engine sound :S
Posted: Wed Apr 05, 2006 9:41 pm
by hot_polo
jsut wondered if anybody had encountered the same problem coming from the engine as me. For some strange reason i hear a funny noise upto around 3000rpm, like a rattling noise from under the engine cover.
Had the cambelt kit done 5 months ago, but it kind of sounds like the belt is rubbing against the engine cover?? is this possible or has anybody had the same thing on their gti??
Posted: Thu Apr 06, 2006 9:54 am
by hot_polo
Posted: Thu Apr 06, 2006 1:01 pm
by hedgehogharvey
hot_polo wrote::(
is your engine cover screw/sitting on propery.
Posted: Thu Apr 06, 2006 1:17 pm
by hot_polo
im pretty sure it is, but why would the sound dissapear after 3krpm then?
Posted: Thu Apr 06, 2006 5:05 pm
by olop_chris
the only noise i can think of is the VVT at 3500rpm :?
and thats a great noise:)
Posted: Fri Apr 07, 2006 2:05 am
by Josh_PoloGTi
Is it a ticking noise?
I had this (up to 3.5k or thereabouts) when my cambelt tensioners went.
Posted: Fri Apr 07, 2006 10:02 am
by hot_polo
Josh_PoloGTi wrote:Is it a ticking noise?
Not really a ticking noise, more like something is rubbing. But i had the whole cambelt kit replaced 3 months ago :x :(
Posted: Fri Apr 07, 2006 10:40 am
by inder
Who replaced it??
VW garage? take it back and explain the sound you are hearing and have them check their work
Posted: Fri Apr 07, 2006 11:04 am
by VDUBGTI
it could be your drive belt, VW's are notorious for this, the auxillary drive belt is actually too wide for the pulleys and hence makes a noise as it rubs against them, locate your drive belt, run the engine and spray some brake cleaner on the belt, if the noise stops then you know its your drive belt.
do not spray any lubricant i.e wd40 on it though! it has to be something that does not lubricate, brake cleaner is perfect
Posted: Fri Apr 07, 2006 11:36 am
by hot_polo
inder wrote:Who replaced it??
it was a local garage.
i though it might be the drive belt actually, i will take the cover off later 2night and have a rummage round :D
i dont think its the tensioners, well i hope not anyway, but it kind of makes sense, the sound goes when the noise of the engine gets deeper. i.e when vvt kicks in, i do hope its not that though :cry:
Posted: Fri Apr 07, 2006 10:56 pm
by andyg
I'd say the sound going away at 3k doesn't relate to the VVT at all. I think the suggestion that it was the VVT is pretty far fetched, you have to listen close to hear the sound of that, and all that sounds like is the engine pitch changing as its taking in more air/fuel.
Usually the drive belt makes a noise when its damp and/or you have left the car for a while. It makes a squeaking noise, a low pitched slow squeak, although that sound dissapears at the revs you speak of. However that is probably down to the fact the car is now making more noise than the belt is.
The rubbing sound you speak of sounds different, do what the others advise and take it back where they did the work.
Please keep us updated, I'd be interested to find out what it is.
Posted: Fri Apr 07, 2006 11:42 pm
by olop_chris
my mistake (im not the best with engines) 8)
Posted: Sat Apr 08, 2006 6:23 pm
by hot_polo
Just got back from the garage, the guy who done the cambelt kit said it could be one of the cambelt tensioners that went :shock:
its only been a few months sice ig ot the kit?
he is taking the car in on monday to do a full check, do you thi its not safe to drive the car then?? :(
Posted: Sat Apr 08, 2006 7:26 pm
by Dangerous Dave
I wouldn't drive the car to be on the safe side, if the tensioner goes taking the belt you will have a very large repair bill !
Posted: Thu Apr 13, 2006 11:09 pm
by hot_polo
just got the car back, apparently some kind of bearing had gone in the engine, somewhere near where the cambelt is.
All fixed now though :D
