Distortion help!!
Posted: Wed Jun 07, 2006 10:21 am
by mk5_sdi
hi fitted some apline type s components to my polo a while ago, really like the vag look so just got a converter to change over to phono plugs however im getting a large amount of distortion through the the tweeters at not a very high volume, any ideas???
Buying a becker mexico pro in the summer, do you think this will cure the problem?? wish i could afford one right now!!! :lol:
Posted: Wed Jun 14, 2006 9:55 am
by mk5_sdi
anyone???
Posted: Wed Jun 14, 2006 10:37 am
by euro-kitch
have u got them amped
u might have the bass up 2 high, fade the bass for the boot u got a sub
Posted: Mon Jun 19, 2006 4:49 pm
by mk5_sdi
yea got an alpine amp powering them, it shouldnt even be big enough to make em go full whack, it still does it with the base down low, i think it might be to do with the in line phono adapter thiny, its pretty crap so hopefully new head unit will cure it!
Posted: Tue Jun 20, 2006 5:25 pm
by tupac2makaveli71
tweeters usually come with a little resister thingy to only let high frequency sound go through it, maybe if you added one on if it doesnt already have one...it could be getting low pass sound and that could be causing the distortion...or maybe your amp is mono and channels out low pass sound clearing out all the high pass?
Posted: Wed Jun 21, 2006 9:06 am
by mk5_sdi
amp is deffo not mono and there are in line crossovers supposed to split the signal dunno what the problem is!
