Noises are doing my head in!! can anyone help??
Posted: Tue Jul 04, 2006 9:05 am
Hi
Hopefully someone can point me in the right direction!
For the last 3 months or so my misses has been complaining about a noise on our polo gti, to cut a long story short ive replaced the rear wheel bearings (not cheap!) which helped, also have cleaned up and lubed a sticky rear calliper which has cooled down the rear wheel!.
Drove it today and it still seems to be making a noise, -well two!
A faint whinning noise which becomes louder if you depress the clutch whilst in motion,
A droaning noise which is noticeable when cruising above 60mph.
Would adjusting the clutch cable (somehow?) help, as it does crunch into reverse sometimes and can feel a bit ‘notchy’.
Car has done 50k, had the pedal box done before we got it, had the clutch cable, cambelt & tensioner replaced about 10k ago and gearbox oil changed and was clean anyway.
Sorry for the vagueness but any help appreciated as its starting to do my head in and my misses is thinking bout getting something else!
Simon
Simon
