door card removal - 6n
Posted: Mon Jul 24, 2006 10:39 pm
by trikstar
basic question i know but is there a specific way of taking off the door cards or do they just pop off?
Posted: Tue Jul 25, 2006 12:31 am
by jamesthomas404
all you gotta do is flip the cover on the interior door hadle off, do this with a flathead screwdriver or sumthin, then undo the two screws hidden behind the cover and then the card is basically held on by clips and the card should come off with a small amount of force. hope this helps!
Posted: Wed Aug 09, 2006 12:34 am
by Biddle
Dont mean too sound stupid ( but probably will) whats the door card?
Posted: Sat Aug 12, 2006 11:33 am
by SpikeyG40
door card is the plastic trim on the inside of the door. i.e the bit on the door which makes up the interior!
Hope that helps!
Posted: Tue Aug 15, 2006 10:08 pm
by polopaul
is this the same with the 6n2? i had the handle off plus the 2 screws earlier n the card still wasnt goin anywhere!!
by polopaul
Posted: Mon Oct 30, 2006 10:09 am
by No Car Yet
i stick a screw driver near the top untill a pop then in the middle untill a pop then at the end untill a pop
by No Car Yet
Posted: Fri Nov 03, 2006 10:03 pm
by willriseley
right ive done this 5 times this week replacing my window mech so im gettin good.
flip off the grab handle cover and undo the 2 screws
then take a screwdriver to the winder handle,place it behind the handle and slide the trim ring up from it, youll see what i mean, this will then pull off.
then get a large flat blade or pry bar and insert under the edge below the pocket and pull CAREFULLY
then the rest will pop off
Posted: Mon Apr 14, 2008 1:05 pm
by Andy1.6
Is this the same for the back doors? Just tried to get them off and I got the screws undone but couldnt get any further
Posted: Tue Apr 15, 2008 12:32 pm
by Andy1.6
Anyone?
Posted: Fri Apr 18, 2008 10:45 pm
by jonnyboy2
willriseley wrote:right ive done this 5 times this week replacing my window mech so im gettin good.
bumping this for later.
Posted: Mon Apr 21, 2008 5:44 pm
by polo_dude
I did a guide for the front somewhere on here. Never got to finish the guide for the rears. For a 5 door that is. Had a few problems with it.
Edit: Link to Guide(It's near the bottom with pics)
Clicky
Posted: Mon Apr 21, 2008 5:49 pm
by Andy1.6
Thanks, would be really helpful as Ive got some speakers to go in if I can get the doors off!
