Shell V-power/optimax petrol?
Posted: Sun Aug 27, 2006 7:17 pm
by Mk2Adam
me and Doug were chatting about this today but i thought i'd try and get everyones opinions on these high performance petrols, i've always just used the plain normal petrol, although my car isn't exactly a performance engine.
but what does everyone else use and what benefits have you seen e.g better performance driving/MPG or whatever?
only asking as i'm tempted to change my fuelling habits to become a v-power only user, bit of a pain as i'll have to go out of my way to my nearest shell garage but if you guys recommend it then i'll do it.
Posted: Sun Aug 27, 2006 8:11 pm
by mysteryboy
Now and then when I changed petrol I thought I noticed that I get more mpg but when I filled up again I get about the same....
I'd say performance petrol is for performance cars (sounds obvious but we'd all like to believe it will make ours faster)
Posted: Sun Aug 27, 2006 8:42 pm
by dino
I went through a phase of using Ultimate Diesel - but then thought 102p was a little steep. I used to think the car ran better but it could have all been in my mind lol
Posted: Sun Aug 27, 2006 10:28 pm
by ModifiedMadness
I always fill up with BP Ultimate as higher octane is recommended for the GTi, even when it is 105.9 / 106.9 a litre
Posted: Sun Aug 27, 2006 10:33 pm
by mysteryboy
^ listen to mr big-shot there
Posted: Sun Aug 27, 2006 10:36 pm
by ModifiedMadness
Don't like paying it but it has to be done, luckily it's gone down about 2p now (wow
Posted: Sun Aug 27, 2006 10:42 pm
by SteB
Designed for higher compression engines, such as those with turbos and superchargers, as the higher octane rating helps prevent pinking, so the majority of us wont see much of a benefit in that respect. However.... its not a complete waste of money because these fuels usual have a lot of detergent type additives that help cleanse the ports of s**t, thus increasing flow and leading to better performance and fuel economy.
In my very honest opinion, I wouldnt go mad on this stuff unless it comes down in price, but it wouldnt harm your wallet to "treat" your engine from time to time
Posted: Mon Aug 28, 2006 6:06 pm
by SpikeyG40
i always use the V-power in the G40. (when did the name change by the way?). but i would say, if you've got the smaller engine, it does hurt to use it now and then. as has been said before, it does clean your engine which is never a bad thing! so maybe, evey couple of months, it might be worth filling the tank up with it!
