Need help fitting BMC CDA
Posted: Mon Aug 28, 2006 8:21 pm
Trying to fit it just now but encountering a few problems....
- The breather filter I got won't fit. It's exactly the same diameter as the crankcase breather pipe itself. I noticed when I look inside the breather filter connection, there are two other diameters. Are you ment to cut it or have I just got the wrong breather filter full stop?
Pics:
Same diameters:
The filter itself:
- Also, which connector do I use to connect to the RHS of the CDA?
Pic:
Each connector has a large diameter on one side which are both the same size, and a smaller one on the other (but are both different as shown in the pic). Now is it the big diameter that goes in the hole and the smaller one to the RHS of the CDA (and if so which one?). Or is it one of the two smaller diameters? I've tried every single combo and none really fit convincingly.
Help much appreciated!
Pics:
Same diameters:
The filter itself:
Pic:
