Eggs
Posted: Sat Sep 02, 2006 2:37 pm
by hedgehogharvey
whenever i start my car i get a smell of eggs coming from the air vents (with the actually air con off). when i am driving its fine, but when i slow down to a stop i can smell it again
any ideas?
Posted: Sat Sep 02, 2006 2:39 pm
by owenjt
Are your friends practical jokers?
Posted: Sat Sep 02, 2006 2:49 pm
by hedgehogharvey
owenjt wrote:Are your friends practical jokers?
are a bit, what could they of done?
Posted: Sat Sep 02, 2006 9:22 pm
by thedees1
I get the same now and again its annoying but it clears up when scrambled
Posted: Sun Sep 03, 2006 12:50 am
by mysteryboy
check inside for a farting midget
Posted: Sun Sep 03, 2006 8:36 am
by inder
maybe cabin air filter needs replacing? check if its all manky
Posted: Sun Sep 03, 2006 10:31 am
by hedgehogharvey
inder wrote:maybe cabin air filter needs replacing? check if its all manky
where abouts is that mate.
Posted: Sun Sep 03, 2006 6:45 pm
by andyg
Perhaps its a hole in the exhaust pipe and the eggy smell you get from the catalyst is comming through the vents?
Posted: Sun Sep 03, 2006 7:59 pm
by DubGTI
^^^I thought that
Posted: Mon Sep 04, 2006 2:21 pm
by VDUBGTI
an eggy smell very often means that the cat is on its way out
Posted: Mon Sep 04, 2006 3:00 pm
by Jordan
Its prob just your pollen filter element that is damp and needing changed. You can take it out n give it a clean and spray it with a after shave or a smell you like.
Posted: Mon Sep 04, 2006 3:08 pm
by RICHARD HARPER
How do ya get the pollen filter out ?
Posted: Mon Sep 04, 2006 3:13 pm
by inder
cabin / pollen filter is under the cowling where wipers are, lift the bonnet and remove the right hand side piece and you can see it underneath
Posted: Thu Sep 07, 2006 3:10 pm
by hedgehogharvey
Hello there it has been to VW today, they are unable to find out what the fault is.. They have carried out a battery test/alternater test encase of over charging, and checked the cat and that isnt blocked etc. They want me to book it in again, however I may have to pay 2 hours+ labour if it is not covered under VW Used car Warrany (£190!)
