Steering Wheel Scrape
Posted: Fri Sep 08, 2006 8:30 pm
by Tigz
Yesterday the steering wheel started to make a scraping noise.
Not heard of this before, any idea what could cause it?
Posted: Fri Sep 08, 2006 9:23 pm
by Biddle
Is it almost as if sand or grit has got into the steering columm?
Posted: Fri Sep 08, 2006 9:52 pm
by Tigz
Yes, I think its the horn contact ring.
A couple of chaps have also suggested this.
Just didn't fancy taking the wheel off to find theres a common problem elsewhere I didn't know about.
Posted: Fri Sep 08, 2006 11:25 pm
by Biddle
Yer mine does this sometimes, its a MK4 btw. But its strange because sometimes it does it and then after a while of driving you relise it has stopped. Strange :?
Posted: Sat Sep 09, 2006 12:04 am
by Biddle
Whatever was in mine must have fallen out. I think its my cars way off telling me it needs a clean :D Quite clever I think of VW to bulid in this feature :wink:
Posted: Sat Sep 09, 2006 9:24 am
by samil87
mine was making a scraping noise a little while back i had forgotten about it until i read this and its actually gone now...probably some trapped dirt
Posted: Tue Feb 06, 2007 1:26 am
by JPR_polo_gti
I had this too and it sounded quite scary (expensive)
but I pulled the plastic around the column a little and the sound stopped, I think it may have come out of place and was rubbing somewhere
Posted: Tue Feb 06, 2007 10:09 am
by tomo87
i had this on my mk4........its something to do with the air bag, you can see a tiny metal clip if u look behind the wheel and you need to bend it a bit with something!
Posted: Tue Feb 06, 2007 5:21 pm
by ModifiedMadness
Mine was doing it a little while ago but seemed to stop itself.
Posted: Tue Feb 06, 2007 5:54 pm
by R.I.T.B
ahhhhhhhhh!
just the topic i was about to post, i'll have a check for it later cos the noise is proper annoying!
Posted: Tue Feb 06, 2007 10:55 pm
by R.I.T.B
tomo87 wrote:i had this on my mk4........its something to do with the air bag, you can see a tiny metal clip if u look behind the wheel and you need to bend it a bit with something!
LEGEND!!!!! it worked, cheers mate!
Posted: Wed Feb 07, 2007 5:40 pm
by tomo87
ha nice one
Posted: Fri Feb 16, 2007 11:41 am
by thedees1
low and behold i went out this morning and reversed out my parking space, and guess what the wheel had started scraping, just as i thought to myself at last ive got everything fixed and the gti is running fine. It just seems to be one thing after another. Anyway the scraping went away after 10min of driving but i will have a look 2mor and see whats trapped
