Xenon adjustment
Posted: Thu Sep 14, 2006 10:27 am
by cjwardy
Had my MOT last week & guy said they were too low.
So adjusted them manually using the screws on top of the light.
Got home & turned the screws a bi more, til they would go no further.
Excellent results, I could now see where I was going, as before I could see about 2ft infront of my bonnet.
Anyway, this only lasted a couple of days & now they have levelled back down 2 feet in front of bonnet. Trouble is now I can't adjust them up as the screws will turn no further.
The lights are damn low & as I live in the sticks it's causing me real hassle.
Anyone know how I could adjust them back up?
Chris
Posted: Thu Sep 14, 2006 10:47 am
by cyhliu
You may have to use VAG-COM as the xenons are are automatically self-adjusting (legal reasons I believe) and so if you lower the car (the sensor is in the rear) it thinks you have a high load in the back and adjusts the beam closer to the car so that you don't blind oncoming drivers!
Posted: Thu Sep 14, 2006 4:50 pm
by BENNO
use vag com 2 free them, then use the screws on the front like you did before then use vag com again to save as home position. should remember that level then as the start position.
Posted: Sun Oct 01, 2006 11:11 am
by cjwardy
I ended up disconnecting the battery for 20mins or so then reconnecting and they sorted themselves out. My mates VAG CD couldnt sort my prob out but this did.
Posted: Sun Oct 01, 2006 6:50 pm
by BENNO
vag com does do it but you need a registered version to access basic settings.
Posted: Sun Oct 01, 2006 11:42 pm
by way_z
now i know why i'm having problems with my xenons!? mine's not a gti & i put the xenons in afterwards, found that im blinding other drivers all the time! i haven't tried adjusting them yet but could anyone tell me more about these rear sensors chyliu is talking about??
