offsets???????
Posted: Wed Sep 20, 2006 11:33 pm
by stani540
can some body explain this to me i really have no clue what the offset means!
because i quite fancy a set of new wheels that are et30 will they fit on a 6n2? as isnt its offset 35
could some1 please explain how it works!
thanks
stani
Posted: Thu Sep 21, 2006 12:02 am
by vdubit
Will be ok if there no wider than 7" and your not going to lower it too much.
explained offsets here, but reading it it does seem quite confusing...
http://www.tigerstyle.co.uk/poloforum/v ... hp?t=24576
Posted: Thu Sep 21, 2006 12:23 am
by stani540
so will a set of et 30's would stick out an extra 5 mm am i right but still fit fine?
Posted: Thu Sep 21, 2006 9:00 pm
by DanDiesel
god don't get me started on offsets!!!
my seat wheels are ET43 and fit fine obviously! (quite inside the arch, thery are 6.5J)
the 17s were 8.5J with an ET30 and they fitted fine but came too close to the arch and had to come off!!
my new 16s (same make and model as the 17s) are an ET35 and these scrape on the calipers!!
its driving me insane!!
Posted: Fri Sep 22, 2006 9:32 am
by VDUB_CHICK
stani540 wrote:so will a set of et 30's would stick out an extra 5 mm am i right but still fit fine?
what size wheels are they?? And is your car lowered?
I have et30's on mine but they are only 14's, sit perfectly, fill the arch out.
They are in line with the arch.
Posted: Fri Sep 22, 2006 5:08 pm
by stani540
yes my car is lowered they are kerscher futuras i think that how u spell it!
