Page 1 of 2
MK5 Bump Strips
Posted: Mon Nov 27, 2006 10:36 pm
by Biddle
Hey are the bump strips on the mk5 the same length as the ones on the mk4? Also Im guessing they come in the black plastic colour, as if they do Il just stick them straight on.
Re: MK5 Bump Strips
Posted: Mon Nov 27, 2006 10:51 pm
by Dee-vub
Biddle wrote:Hey are the bump strips on the mk5 the same length as the ones on the mk4? Also Im guessing they come in the black plastic colour, as if they do Il just stick them straight on.
may be a similar length, but the mk5 ones look wider.
anyways the mk5 ones are just stuck on whereas the mk4 ones clip on. why do you want the bumstrips.....just leave them off, smooth style!
they will be black if they are of a 1.0litre or brand new, but the rest of the models have them colour coded
Posted: Mon Nov 27, 2006 10:56 pm
by Biddle
I was under the impression that the Mk4 ones are just stuck on also. I cant afford to take them off I have to park in a supermarket carpark a couple of times a week, and Ive seen what the damage done by clumsy idiots to other peoples doors.
Posted: Mon Nov 27, 2006 11:07 pm
by Redline
Mk4 rub strips are just glued on.
Mk5 rub strips are clipped on.
Posted: Mon Nov 27, 2006 11:44 pm
by kipper
hang on, im confussed, the 6n2 model, year 2000, are the strips stuck on or clipped on? if clipped on does that mean theyd leave holes if removed? if so how easy to sort out?
Posted: Tue Nov 28, 2006 12:04 am
by loud
mk4 6N is just glue
mk5 6N2 are properly attached and need bodywork if removed
Posted: Tue Nov 28, 2006 12:09 am
by Biddle
Right so to get the mk5s to fit would have to remove the clips and flatten the backs
Posted: Tue Nov 28, 2006 5:21 pm
by vdubit
There not clips they've just got little bobbles pretruding out of em. You could cut them off with a stanley blade. I've got a set if your interested :D
The 6n ones are just stuck on and pull off easy. The glue's a b*stard to remove though!
The 6n2 ones are glued as well as having locating nobs.
Posted: Tue Nov 28, 2006 6:07 pm
by Dee-vub
aw s**t just realised my comment. Totally confusing everyone!
For some odd reason i got them the wrong way round.
mk4 is glued
mk5 is clipped
Posted: Wed Nov 29, 2006 10:22 am
by Dee-vub
CymruPolo wrote:You can buy MK5 ones and glue them on a MK4.
but why, i cant really see the point.....there only bump strips eh. You wouldnt really notice the difference between the mk4 and 5's.
Whats the reason you want to change?
Posted: Wed Nov 29, 2006 7:34 pm
by Biddle
Well on the one side of mine its a bit scuffed, (at least it werent the bodywork) and I need them on the car because I dread to think what state the doors would be in without them. Also the Mk5 ones just seem much smoother. What condition are yours in vudubit?
Posted: Wed Nov 29, 2006 7:44 pm
by vdubit
There all smooth and painted in the original car colour, black magic pearl. Though i could spray them textured black or body colour them red for you if you wanted
Posted: Wed Nov 29, 2006 7:58 pm
by Biddle
Well I want to keep them black if possible because other wise my handles will stick out like sore thumbs. How close to the standard plastic would textured black be do you reckon?
