Vag-Com cable driver
Posted: Mon Jan 29, 2007 2:18 pm
by olopwales
Hi everyone,
just bought a vag-com cable off flea-bay but it didnt come with a driver
(here it is http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... &rd=1&rd=1)
do you know where i can get one, it sort of installed itself but vag-com wont pick it up. all i get is interface:not found
thanks
Lee
Posted: Mon Jan 29, 2007 2:53 pm
by Arnoldo
# For laptops and PCs, download the shareware 409.1 or 311.2 for free or purchase the registered version from Ross-Tech's webside: http://www.ross-tech.com
# Run it and follow the prompts to allow it to install itself.
Note: You must install VAG-COM on your PC's hard disk -- it will not work properly if you try running it directly from a floppy or CD. However, you can use a floppy or CD to move the distribution file from a PC with internet access to another PC that does not have internet access.
# Connect the interface between the computer and the car by plugging one end of the interface into the USB port on your PC and the other end directly into the OBD-II port present in all 1996 and newer VW/Audi passenger vehicles.
Turn the car's ignition switch ON. No need to start the engine.
# Start the VAG-COM program, click "Options", select the correct communications port. Use "Test" to confirm that the program can use the port and find the interface. Then "Save".
# Now it works. Make sure the software can reliably access all the control modules that it should in your car.
Posted: Mon Jan 29, 2007 3:00 pm
by olopwales
already done that, when i click test it just says port:ok interface:not found
Posted: Mon Jan 29, 2007 3:34 pm
by Arnoldo
Em...sry dont know anything more then. Sry :(
Posted: Mon Jan 29, 2007 3:39 pm
by olopwales
cheers anyway mate, sory for the short snappy reply earlier, im in work see and not supposed to be on here haha :P
anyone else have any ideas?
Posted: Mon Jan 29, 2007 8:26 pm
by Arnoldo
Lmao np ;)
Posted: Mon Jan 29, 2007 8:33 pm
by olopwales
haha im not having much luck. having finally installed the driver and vag-com now recognises the cable. IT WONT CONNECT TO THE CAR!!!! haha
oh well ill have another look tomorrow i think getting frustrated now
Posted: Tue Jan 30, 2007 9:56 am
by olopwales
south wales mate, in abertillery nr Newport. Where bouts you from?
Posted: Tue Jan 30, 2007 10:29 am
by D-Dub
I was thinking of buying a VAG-COM cable, but heard you can mess up your car because its not easy to use :?
Im from Newport. Hole of the earth :D
Posted: Tue Jan 30, 2007 11:05 am
by olopwales
suppose somebodies gotta live there haha Jokes
yeah only wanted it for fault codes anyway really, plus my gf's bro has a golf and hes returning it to the finance company who want it in the same condition he had it, so im gonna wipe the lights off the dash.
Posted: Tue Jan 30, 2007 9:07 pm
by gti_black
Posted: Wed Jan 31, 2007 11:35 am
by Ry`
I got the same cable. From the same seller i think. I've got the drivers at home somewhere. I'll try and dig them out for ya.
Posted: Fri Feb 02, 2007 6:33 pm
by Ry`
