Main Beam Bulb
Posted: Fri Feb 02, 2007 5:16 pm
by D-Dub
I bought some Phillips blue vision bulbs. A pair of H1's and some W5W's. Now the W5W's are the sidelights and i thought the H1 bulbs were to replace the ones that you use for main beam. But the guy at the garage said they were the same as the Xenon bulbs
Confused
Posted: Fri Feb 02, 2007 5:29 pm
by ModifiedMadness
I thought the Xenons were H7?
Posted: Sat Feb 03, 2007 8:27 am
by alexperkins
Philips blue vision are xenon filled bulbs with a blue tint, that makes them look like Xenon HID - thats why he said it. The H7 is the dipped beams, but in the GTI, they are Xenon HID as standard
Xenon bulbs are available in H1, H4 and H7. Ive got dipped and main beam in mine with xenon bulbs, and the difference is amazing!
Cheers,
Alex
Posted: Sat Feb 03, 2007 8:54 am
by Si_GTi
I'm pretty certain that the main-beam bulb is an H1 fitment. I've got here a pair of W5W Philips BlueVision bulbs to go in as sidelight bulbs and a pair of H1 Philips VisionPlus which will be replacing my standard-fit main-beam bulbs
just haven't gotten around to getting it sorted yet!
Posted: Sat Feb 03, 2007 8:59 am
by alexperkins
Hehe I was wondering if you had fitted those bluevision sidelights yet
Main beam is def an H1 fitment - to confirm it
Cheers,
Alex
Posted: Sat Feb 03, 2007 9:45 am
by D-Dub
Right ok, so the H1 bulbs that ive got are to replace the main beam bulbs. How easy are they to fit?
Posted: Sat Feb 03, 2007 9:54 am
by alexperkins
Well, in mine it was easy - im not sure as for the GTI due to less space in the engine, but I shouldn't think its much different.
You take off the black plastic case on the back of the headlight, then just unclip the bulb (its the one above the sidelights
) Theres like a metal wire clip that holds the bulbs in place - you can see it if you look into the headlamp unit on the back. Just unclip that, and put the new one in.
Remember though NOT to touch the bulb glass on the new bulbs - it can limit their life by up to 70%!
Also, if you havent fitted them already, the old sidelight bulbs just pull out - a little force might be needed but they will come out
Best to pull on the black holder for the bulbs
Cheers,
Alex
Posted: Sat Feb 03, 2007 11:57 am
by adamvfr
As said the dipped beam is H1, on Gti its the Xenons.
On non-Gtis the main/high beam is H7, isnt it the same on the Gtis?
Posted: Sat Feb 03, 2007 12:24 pm
by D-Dub
Just to clarify im talking about changing the bulb above the sidelight bulb, the one used for high beam. Not the xenon bulb. That black plastic cover just pull off?
Posted: Sat Feb 03, 2007 12:33 pm
by garnier
Heh heh heh, sometimes I wish I was a non GTi owner, ignorance is bliss.
I was initially puzzled when I tried changing my sidelight bulb on my Gti.
The GTi's need to have the front bumper removed to change the bulbs. There's a step by step in the DIY section.
I have a sidelight out and an MOT in April, so my bumber will be coming off at somepoint soon for a bulb change.
Posted: Sat Feb 03, 2007 5:21 pm
by ticki
I was just about say the same thing. Bumper off pal
Thats what you get for having a GTi.
