UK-POLOS.NET - THE VW Polo Forum • Front Splitter?
Front Splitter?
Posted: Mon Feb 19, 2007 8:23 pm
by ticki
I know this might sound a bit silly, but I need to take my front splitter off my car before I drop it another 30mm, otherwise I will never get home in one piece. :lol:
So big question, has anybody taken theirs off? Maybe for a paint job etc, Was it easy to take off? Do you need any special tools?
thanks
Posted: Mon Feb 19, 2007 8:30 pm
by Redline
It's relatively easy, but fiddly.
Theres a screw at either end of the splitter where it meets the wheel arch. The rest of it is all clipped into the bottom of the bumper.
Ideally you need to jack the front of the car up and get it supported on axle stands, or on ramps. Then it's simply a case of using a flathead screwdriver to open up the metal bits that the splitter clips into, then push the plastic bit through and out. You just work your way around doing that.
If you can jack it up and have a look underneath it should all become clear.
Posted: Mon Feb 19, 2007 8:37 pm
by rowdydj
mate done my the other day took 2 mins, undo the screws on either side of the splitter on inner bit of arch and jus pulls out, and fits in just as easy
Posted: Mon Feb 19, 2007 9:06 pm
by ticki
Thanks all. sounds hopeful! :)
Posted: Tue Feb 20, 2007 4:58 pm
by dubpolo
why how low are you now?
