Key problem!!
Posted: Wed Feb 21, 2007 9:24 am
by clees
Hi guys,
Over the past couple of weeks my keys haven't been operating the central locking. The batteries are fairly new so i don't really know what the problem is???
Please help !
Posted: Wed Feb 21, 2007 10:02 am
by Luke'sGti
it could be that they need to be re-synchronised. Mine has done it in the past - all I did was put the key in the drivers side door and locked it - then it seemed to work fine. It worked for me, i'm sure someone has posted about this before.
Hope this helps. Sorry if it doesnt.
Posted: Wed Feb 21, 2007 10:34 am
by LiverpoloGTi
My central locking does that from time to time.
I think it can be to do with low battery power in the fob, causing it to lose sync with the car. To sort mine out I just put the key in the ignition turn so that the electrics come on but not the engine, and hold the unlock button on the fob for about a minute, this normally sorts it out.
Incidentally the VW handbook that came with the car mentioned that the fob can lose sync with your car if you press the lock/unlock button from outside the fobs range.
Hope this helps a bit.
