Amp Help!!!
Posted: Thu Feb 22, 2007 1:37 pm
by Dan1989
What would be the best wattage of amp for my FLI 12" Twin
There RMS is 300 watts each
There Peak is 1000 watts each
Thanks in advance
Posted: Thu Feb 22, 2007 7:51 pm
by gti_black
something that produces 700-800wrms. most ppls will say get a 600wrms amp although it depends on how good you are at setting up your system. as long as you dont slap your gains on full then youll be fine.
its best to have a slightly more powerful amp (for headroom). one thing to remember is your subs will hardly ever see 600w of power when listening to music. this means you can hook up a more powerful amp and still not have to worry about damaging your subs
this seems like a nice amp for the money, although if you willing to spend more then the possibilities are endless :D
http://www.caraudiodirect.co.uk/blaupun ... 43b219f9f1
Re: Amp Help!!!
Posted: Thu Feb 22, 2007 8:15 pm
by ModifiedMadness
Dan1989 wrote:What would be the best wattage of amp for my FLI 12" Twin
Thanks in advance
Do you know the impedance of the subs?
Posted: Fri Feb 23, 2007 11:15 am
by Dan1989
the website says that each one is 4 Ohm
it says on the link below (but remeber i have twin Fli 12")
http://www.fliaudio.co.uk/index.asp?pag ... blank.html
Posted: Fri Feb 23, 2007 11:49 am
by Dan1989
i was talking to someone at a local car shop and he said that i should get the FLI 800s
heres some of the wattages but each line is seprate
4 x 100 @ 4 ohms stereo
4 x 120 @ 2 ohms stereo
2 x 100 @ 4 ohms stereo + 1 x 240 @ 4 ohms bridged
2 x 120 @ 2 ohms stereo + 1 x 240 @ 4 ohms bridged
max power 800watts
any more info on is on the link below
http://www.fliaudio.co.uk/index.asp?pag ... oaded.html[/list]
Posted: Fri Feb 23, 2007 3:59 pm
by ModifiedMadness
An amp that does about 600w RMS at 2ohms will be fine then.
All you have to do then is wire the subs to show 2 ohm :D
