Polo struck by dodgy petrol?
Posted: Thu Mar 01, 2007 10:50 pm
Right, the story goes like this. i moved my car onto the drive earler, started fine- no worries. went to move it about 3 hours later and the starter turns over for a sec then makes a noise like when u try starting it and the engines already running. so stop turning it over! try again a min later only this time the starter is makin a diffo noise when it turns over. went to work and came back, called out the AA.
Chap has a look turns it over for a minute - nothing. i said i thought the starter may be shafted as the noise its making sounded different. he asked what petrol i filled up with, and normally its bp, but my dad borrowed the car on monday and 'kindly' put half a tank of esso in. so told him, and he said that was it then as tesco is esso petrol, and theres a batch with silicone in thats normally used for diesels to stop it freezing in the winter and plus my epc light was on, so one of my airflow sensors is shafted he said. then he hit me with the news that its gonna cost about £3000 to sort it as they need to drop the tank, replace the fuel lines, injectors etc!!! im hopin the petrol is fine and it is just a dodgy sensor, tho it had a new cat + air flow sensor about 2000 miles ago from vw so the signs are not good. does this sound like it could be the petrol bearing in mind it had a service in december and has been running spot on since? am absolutely livid at the mo
