Brake Calipers
Posted: Fri Mar 23, 2007 10:02 am
by hedgehogharvey
Hi All,
I've got new discs and pads all round to put on my car this weekend. And my Calipers need a paint as some of the red as turned pink, and some even flaking off.
What can I use to paint them with.
Someone suggested Hammer-Right-Smooth-Red from B&Q for example
Posted: Fri Mar 23, 2007 10:27 am
by stani540
thats what i used did a top job and is still looking as good a year later!
Posted: Fri Mar 23, 2007 1:09 pm
by Tigz
I was lucky enough to not have to clean mine.
Disc cleaner is great for getting all the crap you dont see off the calipers.
So after cleaning with a wire brush, spray some brake disc cleaner (Can be bought from any motor facters for a couple of quid.) onto the caliper and the carrier.
Use some wire wool and wipe over.
Then use a tack cloth (What a bodyshop uses to remove any dust being painting) over it all, and paint on uses a good quality paint brush.
Ask for Hammerite Direct to rust Metal Paint.
You want to choose a Smooth finish.
The silver or Black paint also looks good for tidying up the Hubs while the brakes are off.
Here is what I used.
The Red spray was used for spraying the carriers, as the wierd shape makes it hard to get to with a brush.
The Calipers were painted with a brush, as it take a more durable finish as Im always knocking them when Im ajusting my coilovers.
And I always hit it when Im take the nuts out the wheels lol.
Take you time with it, and it will look great.
Pic is a little large to post.
But heres what you need.
Click Here.
Before and Ater
Posted: Fri Mar 23, 2007 1:24 pm
by Kam Racing
E-tech make a Caliper Paint kit that includes a spray cleaner and brush for £19.99 not sure if its cheaper/more expensive than the Hammerite though
Posted: Fri Mar 23, 2007 1:34 pm
by Tigz
Hammerite is about £5 for a tin, and £6 for a can of spray.
You'll get more out of a tin of hamerite, its more durable, and theres a better choice of colours.
Posted: Fri Mar 23, 2007 1:41 pm
by GTILass
i bought somethin from b&q a different make to hammersmooth
all does the same job though just half the price of calliper paint
Posted: Fri Mar 23, 2007 8:40 pm
by oscar olop gti
Hammerite smooth £5 from Halfords used it on my carriers, needed 2 coats but it works a treat.
