Audio Install - help
Posted: Fri Apr 13, 2007 4:16 pm
by shantybeater
I managed to get my boot build from my mk4 to fit in me polo
Only problem is I can't seem to find a hole through to the engine bay?? can anyone help???
There is what look like a semi-circle cut into the carpet area with a rubber thing behind, is that it? do I have to drill any holes??
Posted: Fri Apr 13, 2007 4:28 pm
by hedgehogharvey
took me hours to find one. its under the glove box so to speak where another black cable goes though.
Posted: Fri Apr 13, 2007 4:30 pm
by shantybeater
is this the rubbery thing?? is it actually a hole???
Posted: Fri Apr 13, 2007 7:28 pm
by Alex_6n2
It's a hole with a rubber bung in it.
The bung has a hole in it for you to feed wires through.
As you look at your engine bay its on the RHS above the gearbox, in between the suspension strut and engine
Posted: Mon Apr 16, 2007 9:19 am
by Luke'sGti
as above its an absolute c*nt to do it though - took me and my mate about 30 mins using a coathanger to pull the lead through.
Posted: Mon Apr 16, 2007 9:43 am
by shantybeater
Got it through in the end!
problem solved...apart from i broke the fuse in the process so just jammed the power lead together with some tape....nice and dangerous!
