New clutch or not?
Posted: Mon Apr 30, 2007 11:05 am
by Bryony84
My poor car is off for its gearbox rebuild on wednesday, was just wondering if I should be getting the clutch cable changed at the same time seeing as the gearbox is out. I've got the standard clutch at the moment and not sure whether it is better to stay standard or get the sachs clutch!?
Posted: Mon Apr 30, 2007 12:01 pm
by Ronal Low Polo
if your not running stupid power then the stanbdard clutch will be fine, you may aswell change the clutch cable as when you get the car back it`ll fell like new!!
Posted: Mon Apr 30, 2007 12:37 pm
by garnier
I think most garages would recommend that you change the clutch if the gearbox is coming off, but then it would depend on when you last had a clutch fitted. If you don't know when the clutch was last replaced it'd be a good idea. Best to get the mechanics opinion on your current clutch.
Also from what I've heard the sachs clutch is pretty good, so I'd count it as an 'upgrade' :)
Posted: Mon Apr 30, 2007 2:00 pm
by Redline
garnier wrote:Also from what I've heard the sachs clutch is pretty good, so I'd count it as an 'upgrade' :)
Agreed. For years I've heard nothing but good reports about the Sachs clutch. If you're going to do it, and can afford to, might be best to go one for the one that has the best reputation.
Posted: Mon Apr 30, 2007 2:16 pm
by Bryony84
How much do the sachs clutches go for? And do you think the garage would mind me turning up with one and asking them to fit it while they are doing the gearbox?
Posted: Mon Apr 30, 2007 2:44 pm
by GTILass
Bryony84 wrote:How much do the sachs clutches go for? And do you think the garage would mind me turning up with one and asking them to fit it while they are doing the gearbox?
shouldnt bother them either way - your paying them to do the work
Posted: Mon Apr 30, 2007 2:49 pm
by LiverpoloGTi
I had my gearbox and clutch replaced month, the gearbox had failed and the clutch only had 6mths life or so left, The garage charged my £94 for the Sachs clutch kit and didnt add anything on for labour.
The new clutch is nice and light although im not best pleased with my reconditioned Black Diamond gearbox (gear stick rocks back and forth when coming on/off power in 4th gear, never did this on old its old box).
Posted: Mon Apr 30, 2007 2:56 pm
by Bryony84
That rocking thing in 4th your box does, mine has done it ever since i've had it, on the original box. Apparently a good few other people on here have a box that does the same thing and its not a problem. Might just ask the garage about the sachs clutch when i take it in!
Posted: Mon Apr 30, 2007 3:06 pm
by Redline
Yup, you might as well ask them about the Sachs clutch.
And as for the 4th gear thing, yes mine does that as well.
Posted: Mon Apr 30, 2007 3:40 pm
by Luke'sGti
Bryony - I was told to change my clutch at the same time as my gearbox being out - for a sachs clutch kit it cost me £90 via the vag garage i was getting the work done at - for the difference before and after i would suggest getting it done - mine felt like a new car when i got it back in comparison.
Posted: Mon Apr 30, 2007 4:03 pm
by garnier
if you look at a pic of a gearbox, you'll see one end has a circular recess for a clutch to fit into (dinner plate sized). The gearbox needs to come off to get access to the clutch, so if the box is coming out anyway it's not really much extra work to change it.
My gearstick rocks back and forward as well - there's a knack to stopping it by the way you use the clutch - smoothly! The garage told me my gearbox mounts were worn.
Posted: Mon Apr 30, 2007 5:05 pm
by Dee-vub
my 1 litre polo had the rock in 4th gear.
and my 1.4 8v has had it on both its gear boxes....Think its just a mk5 thing throughout the range :roll:
