UK-POLOS.NET - THE VW Polo Forum • Footwell lights
Page 1 of 3
Footwell lights
Posted: Tue Feb 18, 2003 10:31 am
by tdisport
I really want to add footwell lights like the new mini to my polo but dont know how to. Any ideas you guys?
Thought about connecting LEDs to the puddle lights on the doors so they come on the same time and then sticking them under the tray thing thats runs under the glovebox/steering wheel. Do know much about electrics though!
Any help appreciated.
tdisport.
Posted: Tue Feb 18, 2003 11:17 am
by polo2k
thees a guy on ukmk4`s called foxy and he does complete kits. i think josh has em fitted to his mk5
Posted: Tue Feb 18, 2003 4:09 pm
by mole
Should be pretty easy to do.
Find the wire that goes into the door for the "puddle" lights. I reckon you could pull the light out, find the colours and then *try* and find them inside the car, where the wires from the doors come thru. Failing that, try and run some new wires into the door.
Run a wire from them, to the new LEDs (I assume you mean the "bulbs" that are made up of loads of LEDs, as opposed to normal single LEDs.)
Fix them under the tray thing.
Sorted I'd say.
Posted: Tue Feb 18, 2003 4:41 pm
by des_pd_ tdi
Some of the larger Halfords branches do some blue lights for the insides of cars, handy if you want to do it on the cheap.
Personally I'd opt for pukka VW puddle lights remove the red filter and mount them either side of the transmission tunnel or corners of the front footwells.
Des
Posted: Tue Feb 18, 2003 7:40 pm
by Josh_PoloGTi
Hi all
Right, I've had blue hyper bright led footwell lights for quite a while now and I love them.
I have just one hyper bright blue led in each footwell, connected to the back of the heated rear window switch. They are on whenever the headlights are on, but I have a separate switch for them just in case (although I have them on all the time!)
The blue from the leds matches the blue illumination really well.
BTW, I've replaced the courtesy light bulb with 3 of the same leds, 1 points to the centre console and the other 2 point to the doors... Nice blue glow inside the car and when you open the doors, you get a nice "puddle" of blue light on the ground!
Posted: Tue Feb 18, 2003 8:41 pm
by mole
Sounds interesting Josh :)
Posted: Wed Feb 19, 2003 6:21 pm
by Josh_PoloGTi
See the DIY section for a wiring diagram
Posted: Thu Feb 27, 2003 10:46 pm
by Guest
Hmm,
You guys all appear to have Puddle lights in the doors...
I have the reflectors, but there isn't any lights behind them.... Strange..
Posted: Fri Feb 28, 2003 9:25 am
by des_pd_ tdi
VW cost cutting again. If the puddle lights are in the brochure for the year of manufacture then they should be on your car.
I'd kick up a fuss but you've probably have enough already
Lights
Posted: Fri Feb 28, 2003 10:04 am
by tdisport
If you've got 1.9 Tdi sport (3 door) then you SHOULD have puddle lights that work. Looks like a trip to VW!!
Just remembered the other day, VW Sharons have puddle lights fited to them as standard, so might investigate how they fit etc. and put some of them in to keep things semi-standard with VW parts etc...
Will investigate...
Posted: Fri Feb 28, 2003 10:36 am
by mole
I've got lots of things I shouldn't because it's an early car I think.
Maybe why you haven't got them?
Posted: Fri Feb 28, 2003 11:46 am
by des_pd_ tdi
I have them on my Sport 1.9 TDI 3 door Year 2002 model
Posted: Fri Feb 28, 2003 11:59 am
by mole
Should have them then sparky by the looks of things.
Posted: Fri Feb 28, 2003 2:57 pm
by Guest
Maybe i do. Perhaps VW forgot to put the bulbs in, though i doubt it.
The Beetle had them, kind of half red - half white. I'll have a look into it...
:cry:
Posted: Fri Feb 28, 2003 4:27 pm
by mole
Probably did :roll:
Yeh, just like this:
They just pull out, so pull one out and see if its wired up/got bulb.
