UK-POLOS.NET - THE VW Polo Forum • Lock problem
Lock problem
Posted: Fri May 25, 2007 7:33 pm
by mk4_bandit
Ive just broke my lock on my door, so it needs replacing,
anyone know if the handle, lock mechanism and central pump thing from a 97 polo will fit into a 99 polo??
cheers
Posted: Fri May 25, 2007 11:08 pm
by alexperkins
It should fit no problem - they are the same mechanically and aesthetically so it shouldnt be a problem - its only 2 years not like 10 :P
Posted: Sat May 26, 2007 12:24 pm
by mk4_bandit
Thats true but their was a change in lock components in 97 so thats why it might be different?
Ive been into vw and asked them what they would do and they have no idea (no suprise there) and the bloke at my local scrappy said it might fit with a few modifications, but he wasnt sure either.
Posted: Sat May 26, 2007 1:29 pm
by Robi mk4
just get a new car olie! n i want my alloys back.....im no help :lol:
Posted: Sat May 26, 2007 4:13 pm
by mk4_bandit
How about shutup pr*ck they were my alloys on the first place i just bought them back! 8)
If anyone apart from this goon could help, it would be appreciated! :D
Posted: Sat May 26, 2007 4:59 pm
by alexperkins
I'd say a late 97 model should be fine - regardless, a scrappy should have the various bits you need to make it work from maybe even a 99 or 98 polo :) I can take a look down my local if you want?
Posted: Sat May 26, 2007 7:03 pm
by Robi mk4
u hurt my feelings! bt ill try n help dnt see y it shudnt work matey, i need 2 ask u bout the new hub aswell chat later
Posted: Sun May 27, 2007 11:51 am
by mk4_bandit
alexperkins wrote:I'd say a late 97 model should be fine - regardless, a scrappy should have the various bits you need to make it work from maybe even a 99 or 98 polo :) I can take a look down my local if you want?
Dont worry mate, ive asked around. It'll defanitley fit if its the later 97 model but also if its the early one it will fit with some modifications.
thanks for the help :P
Posted: Sun May 27, 2007 12:17 pm
by henry01
olie you w**k...what have you done now??? you two are arguing like old women,
olie did you sort out your producer from our drug dealing the other night?? the cop was a prick when i went in
