UK-POLOS.NET - THE VW Polo Forum • 9N guys running subs need your help!!!
Posted: Sat Jun 02, 2007 9:21 pm
by GT_Raven
1) Is there a grommit in the bulkhead i can run the power cable through?
2) where have you hid the cables when running them through the car if under the trim how does the side trim come off?
3) will i have any problems running the amp and sub with the vw gamma cd player for now. guna update the headunit soon but want to run the standard one for now.
GT_Raven :)
Re: 9N guys running subs need your help!!!
Posted: Sat Jun 02, 2007 9:43 pm
by dino
GT_Raven wrote:1) Is there a grommit in the bulkhead i can run the power cable through?
GT_Raven :)
Howdy!
There is a gromet in the passenger foot well that goes through the bulk head. The trim at the bottom of the door/body just clips on so can be carefully removed by pulling it. I ran it all the way up the side of the car and then under the rear seats. I have no problems with running the amp/sub off the standard HU
Posted: Sun Jun 03, 2007 3:36 pm
by GT_Raven
thanks had a look today and found 2 potential areas in the footwell not sure which on to use and both seem to have something screwed on from the engine side.
it also looks very tricky to find the hole when looking from the engine bay any pictures of your wiring dino?.
Posted: Sun Jun 03, 2007 5:20 pm
by dino
Can't really get a pic of where it comes through in the engine bay as it is tucked away and the wire is now black where its been in there 2 yrs nearly.
Posted: Sun Jun 03, 2007 9:19 pm
by Slimbo9n
hi pal in a 9n and golfs if you look under the dash on the drivers side you will find the main feed from the battery into the car. this is where i have my amp run to and is perfectly fine to use as it is aprox a 65amp feed witch is more than enough for any amp. also makes it handy if you use a circket breaker type fuse to turn the base off if you dont want it on for some reason because i have it located behind the removable pannel under the stearing wheel. also if you are connecting it to a gamma go to an audio shop and get the proper lead like i did plugs into the mini iso plug at the top of the head unit (blue,yellow and green) and gives you front and rear outputs and a proper remote feed to turn amp on. if you need some pics please ask me and ill take some for you and this way you dont have to get through the bulkhead and make your car leak water.
Posted: Mon Jun 04, 2007 12:22 am
by ModifiedMadness
Or you could go through the bulkhead and do it properly?
I've never spoken to anybody who's had water leaking through a hole for power cable.
I've got 0 guage through mine with a 200amp fuse off the battery (which the audio place drilled) and haven't had any water in at all.
Posted: Mon Jun 04, 2007 9:58 pm
by Slimbo9n
either way is perfectly fine if your running mega stuff like it sounds modified is then go to battery but that feed in the car is 65 more than enough. 200 amp fuse that will never blow lol battery only has about 110 cca on a tdi lol.
Posted: Tue Jun 05, 2007 4:46 pm
by GT_Raven
hi yeah pics would be helpful
quick question jsut want to check that these are the correct removal keys for the gamma radio
cooks vw said they were right but just want to check
Posted: Tue Jun 05, 2007 11:13 pm
by Slimbo9n
yeh there fine
Posted: Wed Jun 06, 2007 7:38 am
by alexperkins
Slimbo9n wrote:yeh there fine
That means theyve changed them in 3 weeks :P When I got mine from VW the ends were flat with little notches in them. I think those keys are for the newer Deltas and upwards.
Here is the GAMMA and BETA removal keys:
Posted: Wed Jun 06, 2007 1:44 pm
by GT_Raven
lol yeah dont think they were the right ones. my headunit is now out however was a pig to get out though so guna leave it out untill i buy my new head unit.
Can i use the vw cd player with my new head unit looking at geting a Pioneer DEH-P75BT.
Posted: Wed Jun 06, 2007 4:37 pm
by ModifiedMadness
If you mean the changer, then unfortunately no.
You'll have to buy a Pioneer CD changer for it.
