Finally fitted my BMC :D
Posted: Sun Jun 03, 2007 9:56 pm
by Kam Racing
finally got round to fitting it yesterday. pretty easy to fit, though had to trim the silicon bend to get it to fit under the bonnet as the silicon bends are larger than the rubber bends they used to supply. Certainly feels a lot more responsive now and it now has a deep growl :thumbsup:
Posted: Sun Jun 03, 2007 10:54 pm
by alexperkins
Nice job. It does look good in silver. I received my last filter in the post yesterday :) Fitted it and works a treat.
im just glad I had some pipe lying about to channel the crankcase breather down the front away from the air vent for the interior - fumes are rather unpleasant :P
Posted: Sun Jun 03, 2007 10:55 pm
by partridge88
sweet that. how much are they?
would you see much gains without a remap?
I'm curious as to where the cold air feed is on the 6n2, usually feeds are behind the front grille, its funny to see an airbox so far from the front of the engine bay.
Posted: Sun Jun 03, 2007 10:58 pm
by alexperkins
Standard air feed goes into the left wheel arch - follow the pipe:P
They cost £160 - jon (kamracing) was doing a group buy for a little less or that if i remember correctly, but that might be over now.
You should gain 1-5hp depending on your setup.
Posted: Sun Jun 03, 2007 11:09 pm
by Mouse_GTI
I can no longer smell the fumes from my breather filter. Or maybe I'm used to it
Posted: Mon Jun 04, 2007 1:57 am
by Kam Racing
partridge88 wrote:sweet that. how much are they?
BMC's dyno recorded just under a 6 brake increase with the BMC over the OEM filter but not sure whether they remaped it after.
I can do you a silver one at the GB price as one guy pulled out...
http://www.kam-racing.com/product_info. ... cts_id/474
if your after a black one i'd have to order it in as i've just run out of stock... should only be a couple of days extra to wait though...
Posted: Mon Jun 04, 2007 12:57 pm
by New B
Mouse_GTI wrote:I can no longer smell the fumes from my breather filter. Or maybe I'm used to it
I had the same thing I just stuck my engine cover back on
Posted: Mon Jun 04, 2007 2:46 pm
by alexperkins
I got a bit of rubber pipe from a scrappy, and piped the crankcase breather all the way down to behind the front left foglight next to the fuel filter - solved all the problems heheh :D
Posted: Mon Jun 04, 2007 3:47 pm
by tomo87
mine is definatly the wrong way round! will that make much difference?! lol
Posted: Mon Jun 04, 2007 5:01 pm
by alexperkins
Howd u mean - the bmc is round the other way?
In a non-gti/non16v engine, the throttle body is in the middle, which means there isnt enough space to point it left. Mine points towards the coolant tank i have that problem:P
Posted: Mon Jun 04, 2007 6:27 pm
by tomo87
im confused....mines a gti - but the side that says "engine side" is facing the car
Posted: Mon Jun 04, 2007 6:53 pm
by Redline
The end labelled "engine side" should be the end connected to the 90 degree bend off the throttle body.
Posted: Mon Jun 04, 2007 6:55 pm
by tomo87
im all good then! cheers mate
