UK-POLOS.NET - THE VW Polo Forum • Curse it, my water pump's leaking
Posted: Thu Jun 14, 2007 2:09 pm
by quinny
Hello.
My water pump is leaking on my mk2. I suppose I'll have to change it.
How gay.
It's one thing to another with this car.
Posted: Thu Jun 14, 2007 2:17 pm
by quinny
17050 WATER PUMP-BQ PO 1.3 1/77 >10/90
Can anyone verify that this is the correct part number from GSF for an MH coded 1986 1.3 engine?
Posted: Fri Jun 15, 2007 8:43 am
by SpikeyG40
can't help with the part number for ya, but my advice would be to change the cambelt at the same time. that is if it hasn't been done in a while!
also, when you get the pump, check that it spins freely! i've been given a couple from vw and the impeller will not spin without some force!
i think if you were to get it from vw, they like to have your old one in exchange! :wink:
Posted: Fri Jun 15, 2007 10:21 am
by quinny
I'm not bothering with a VW one.
I'm not going to be using this car as a daily for much longer and I have two possible donnor engines for this, GT and G40, I just need a G40 wiring loom and a mk3 gearbox.
Posted: Fri Jun 22, 2007 10:00 pm
by nick0323
Delete
Posted: Sat Jun 23, 2007 3:54 pm
by quinny
Nah, the headgasket has just gone, that was the cause of the water pump leaking and eventually failing.
My waterpump and heagasket are only 5,000 miles old, I am not a happy bunny.
For the third year running I've had a car booked on the UK-P stand at expo, for the third year running my car has died the day before, my friend chris will take my place with his eaton'd G40 as it did last year.
Posted: Sun Jun 24, 2007 7:58 pm
by hypojam
I dont understand how you have so many engine problems, Mine just takes so much abuse all the time and it just loves it...
Anyways first dibs on some parts when you tare ye old mk2 apart, mainly the gearbox/anti-roll bar/linkage... :D
Posted: Mon Jun 25, 2007 12:11 am
by quinny
Nah, with the headgasket, waterpump and timing belt done it shouldn't have any more problems.
It's just one of those things.
