My Polo GTi Rolling Road Results
Posted: Sun Jun 17, 2007 9:11 am
Not too bad I suppose, The engine is completely standard. I'm running V-power fuel.
Probably the Worlds greatest Polo resource
https://uk-polos.net/
Surely the figure will be horsepower at the wheel, not at the fly so you would expect it to down.Dee-vub wrote:not too bad???Your 6bhp down are you not, i'd be seriously pissed off at that!
Well! I feel I can claim back those 6bhp if I go back better prepared. My airfilter was filthy, tyre pressures were down. amongst other things. Many cars run under the expected bhp, so I was not too dissapointed. if I ran 110bhp or below then there would be real cause to investigate and solve the problem.Dee-vub wrote:not too bad???Your 6bhp down are you not, i'd be seriously pissed off at that!
Run at the same time as me mate. would be good to compare under the same conditions. I went down with the Section 5 lot. do wanna come along next time? If your going on your own, give me a shout, because I want to re-run soon.Redline wrote:Surely the figure will be horsepower at the wheel, not at the fly so you would expect it to down.Dee-vub wrote:not too bad???Your 6bhp down are you not, i'd be seriously pissed off at that!
Just realised my Auntie's brother owns and runs that place, should get my GTi on there sometime.
You could have a point there likeDangerous Dave wrote:Looking at the graph he backed off a bit early my peak power was at around 6700revs when mines was on the rollers, I suspect if it had been wound round more you would have made more power, mies had the slight dip in power around 6k before it started going back up again.
Yeah I'll have to get in touch with him and see about getting both of ours on there, be interesting to compare them back to back.ticki wrote:Run at the same time as me mate. would be good to compare under the same conditions. I went down with the Section 5 lot. do wanna come along next time? If your going on your own, give me a shout, because I want to re-run soon.
good manRedline wrote:Yeah I'll have to get in touch with him and see about getting both of ours on there, be interesting to compare them back to back.ticki wrote:Run at the same time as me mate. would be good to compare under the same conditions. I went down with the Section 5 lot. do wanna come along next time? If your going on your own, give me a shout, because I want to re-run soon.
