BMC on 1.4 8V???
Posted: Tue Jul 10, 2007 12:23 pm
has anybody got a bmc cda on there 1.4 8v im thinking of getting one? what other parts do you need to fit it????
Probably the Worlds greatest Polo resource
https://uk-polos.net/
Do you know the internal diameters of the breather pipes? if so PM me and i'll price up a kit with 2 breather filters for itdubpilot wrote:well i dont have a bmc filter but ive done my homework...
you need a:
- silicon (or rubber) 90 degree bend that you need to modify to attach the two breather hoses on either side of the airbox.
if you cant manage that then you need:
- two breather filters for each hose.
then ofcourse:
- your flexible cold air feed.
fix each component to each other using jubilee clips then take it for a spin and enjoy.![]()
heres a pic to give you ideas!
I'd have thought so too, so that the filter removes at least some of the crap from the breather pipe rather than venting it almost straight back into the throttle body.david burton wrote:I thought the breather should be before the filter....... maybe I'm wrong here.
one of the pipes is 19mm ID and the other is 10mm IDKam Racing wrote:Do you know the internal diameters of the breather pipes? if so PM me and i'll price up a kit with 2 breather filters for itdubpilot wrote:well i dont have a bmc filter but ive done my homework...
you need a:
then ofcourse:
I get about the same fuel consumption in my GTi with one fitted.. I must be driving like a grannyalexperkins wrote:Why you selling up craigBMCs are the best (though they plummet fuel economy into the ground and bury it!)
Is that a 70mm to 50mm reducing bend? Or is there an adapter included? AFAIK the intake is 50mmKam Racing wrote:the best price i can do for the following kit is £180 delivered or £185 if you would like the Limited Edition silver one
CDA70-130 (Including cold air feed and 2 nylon reducing rigs)
10mm Green breather filter
19mm Green breather filter
70mm diameter 90 deg silicon bend
you can get to them via this link
http://www.kam-racing.com/shop.php/cPath/116
can someone double check this for me please? a 70>50mm one would unfortunately make each kit £5 more expensive8080 wrote:Is that a 70mm to 50mm reducing bend? Or is there an adapter included? AFAIK the intake is 50mmKam Racing wrote:the best price i can do for the following kit is £180 delivered or £185 if you would like the Limited Edition silver one
