UK-POLOS.NET - THE VW Polo Forum • Got a Bit of damage to repair...Advice required
Posted: Sun Jul 29, 2007 7:44 pm
by dipsyd
Well I've been meaning to post up here to get some advice on how to go about this....
Well here's the dent:
What am I required to do, done a bit of bodywork before, Im looking for a quick and cheap fix for the time being? Just don't know which way to go about this!
Thanks In advance!
Posted: Sun Jul 29, 2007 10:14 pm
by dino
tad more than a dent lol
Will need filling and spraying.
Posted: Sun Jul 29, 2007 11:23 pm
by vdubit
The car has already been repaired on that panel. Thats filler chipped off. Its an easy repair, bit more filler, sand with a block. Get an aerosol mixed up in the right colour and spray up to the drainage line beneath the light. 30 min job max!
Posted: Tue Jul 31, 2007 10:05 am
by dipsy_d
Nice one...I was sure thats what I had to do. Right couple of pointers:
What Filler should I use?
Halfrauds can mix the paint up, will it need a spot of primer?
What grades/types of sandpaper do I require?
Posted: Wed Aug 01, 2007 8:04 pm
by vdubit
Sorry mate, i will reply to the pm in better detail later, proper busy right now! Use really rough paper to start with, about 80 grit. rough the whole area up, try get it back to metal and the existing filler to a point where its solid. Apply the filler in several coats, sanding between (80grit paper on a block) until its nice and level. Sand with 240 grit paper (again, on a block) to lose all scratches. Prime several times, until its lovely and smooth (use a hi build primer) flat the primer using 600 or 800 grit wet and dry paper (use wet). Build up coats of even paint until its lovely and shiny. If it comes out dull, use 1500 grit paper to very carefully flat back the paint. T-cut lots and then polish.
Use P38 easy sand filler. Sandpaper from b&q and an aerosol from halfords.
Hope this helps 8)
