Can anyone solve this one ?
Posted: Sat Sep 01, 2007 8:13 am
by thedees1
Well here goes,
The good old engine electric has been on for a while, and when i download the system with vag-com i get the 2 following errors in the engine module,
1. Camshaft timing adj (bank 1) intermitent
2.EVAP purge valve intermittent
I decided to have a look through every fuse, I came across 2 that had blown 1 for the heated rear windscreen and the other (fuse number 30 ) for the engine electric system.
I cleared all the fault codes and reset the light and replaced both fuses,after a day of driving without the light coming back on,the next day i started her up to find the light on again. i checked fuse number 30 and it had blown again, ive now tried the above 3 times but fuse 30 keeps blowing.
Does anyone have any ideas why it my be doing this.
Posted: Sun Sep 02, 2007 11:33 pm
by dubpolo
its shorting out somewhere or a faulty part is causing it to blow.
hope you find out what it is, i get things like this and being a mechie it makes my brain over heat!
good luck
Posted: Mon Sep 03, 2007 3:39 pm
by sorted
Was on my ECU after the timing belt slipped.
