Headliight load sensor where is it?
Posted: Sat Sep 01, 2007 8:19 am
by thedees1
Im getting a fault code saying,
1.Headlight load level sensor (left rear) implausible signal
Where can i find the sensor?
Posted: Sat Sep 01, 2007 8:27 am
by Dangerous Dave
Its on the rear axle. Not sure where on it though I always thought there was only one sensor however from he message it looks like there is two.
Posted: Sat Sep 01, 2007 11:45 am
by tegwin
I think...
If you take off the passenger side wheel you can see a little pushrod type thing comming off the main axel beam going almost vertically up to a little sensor block with wires...its pretty obvious if you hav ea poke around in the left hand rear under arch area
Posted: Sat Sep 01, 2007 3:08 pm
by 8080
Posted: Sun Sep 02, 2007 12:24 pm
by alexperkins
Its actually in the door! Well thats what ETKA says anyway :D
