Laquer spraying help
Posted: Wed Sep 12, 2007 10:32 am
by Tim_GTi
what do i when it runs :?
Posted: Wed Sep 12, 2007 12:58 pm
by Tetsuo_83
What did you spray?
You have to sand it back down and start again unfortunately, but depending on what youve sprayed it on, you may get away with letting it harden for a week then gently wet sanding it flat with fine paper/block and polishing it back up.
Posted: Wed Sep 12, 2007 8:23 pm
by Tim_GTi
Tetsuo_83 wrote:What did you spray?
stubby drivers mirror, when u say sand back dwn, du mean all the way bak to primer?
Posted: Wed Sep 12, 2007 10:27 pm
by garnier
assuming you've used aerosol for this job.
You can dry aerosol in about 10 minutes using a hairdryer, leave it to cure for at least an hour after that. Then rub out the run using 1200 grit paper (wet). You don't have to rub back to the primer, but since aerosol is so thin chances are you will easily go through to the primer unless the base coat is really thick. No big deal though if you do.
Use many light coats, rather than a few heavy coats. Try not to pass the can too close to the object or it will run if the spray hits close.
Posted: Thu Sep 13, 2007 12:16 am
by Tetsuo_83
Erm.... everything he said really. ^^^ word for word. (damn mind readers)
Posted: Thu Sep 13, 2007 10:24 am
by Tim_GTi
garnier wrote:assuming you've used aerosol for this job.
cheers dude i'll give it a try!
