UK-POLOS.NET - THE VW Polo Forum • A different ABS light issue
Posted: Thu Sep 13, 2007 1:13 pm
by Luke'sGti
Funnily enough when some of you guys were saying in a previous thread that your ABS light had come on then gone off again you must have cursed my car - as mine was ok until you posted that :?
Been to the garage today and he has linked it up to the computer and it looks that at some point in the future I'm going to need a new ABS pump/unit - has anyone had this before, if so do they know the cost for replacement? Any help would be greatly appreciated. :)
Posted: Thu Sep 13, 2007 1:31 pm
by DanDiesel
new pump/unit eh? when my light came on, it turned out to be a rear ABS sensor so this got fixed under warranty and then a year later the light came on again and it turned out to be the other side rear ABS sensor! this wasn't fixed under warranty!
Posted: Thu Sep 13, 2007 1:47 pm
by Luke'sGti
thanks for the help - I'll ask him to check that - but that wasn't what came up on the diagnostics software that he used - although i'm not sure if it would differentiate between the two
Posted: Thu Sep 13, 2007 2:15 pm
by DanDiesel
i would think that it would differentiate mate but you could always get him to check just to be on the safe side!
Posted: Thu Sep 13, 2007 6:26 pm
by ModifiedMadness
I had that, when they plugged it in and checked he said I need a new ABS Control unit.
It's somewhere between £500-£600 (the price I had included something else as well) from a VW specialist.
Posted: Thu Sep 13, 2007 6:28 pm
by Andrew_robert87
my ABS light is on constant aswel :S hope it aint gonna be that much :( aint had it looked at with the computer yet, just had it looked at by a mate in a garage to make sure my brakes are ok, which they are, so its gotta be either a sensor or that control unit
Posted: Thu Sep 13, 2007 10:31 pm
by polo_gti21
ran mine throught VAGcom and mine was the rear speed sensor so i have cleaned both sides and its all cool.
Posted: Fri Sep 14, 2007 9:24 am
by Luke'sGti
Thanks for the replies guys.
I rang him up last night to double check, and he said that it said "high reading" or something to that effect - so I'll probably get the sensors checked first - can anyone tell me how much new sensors are likely to cost - if it's going to be a lot cheaper, I'd obviously rather get those changed first just incase, before shelling out £600 (ish).
Thanks in advance :)
Posted: Fri Sep 14, 2007 7:16 pm
by polo_gti21
not sure on the price of the sensors but i cant be to much say £50 tops (please dont quote me on that tho its just a guess) to clean them just take the rear brakes off and they are behind the discs.
Posted: Fri Sep 14, 2007 9:12 pm
by DanDiesel
iirc, one of my sensors cost around £90 fitted!
Posted: Sun Sep 30, 2007 9:40 pm
by metalblue
polo_gti21 wrote:not sure on the price of the sensors but i cant be to much say £50 tops (please dont quote me on that tho its just a guess) to clean them just take the rear brakes off and they are behind the discs.
I had mine replaced at 20 something quid each - ended up needing a new abs pump thou - that cost £750 all in :shock:
I tried fitting a 2nd hand pump first but you have to get a new gen part, this has to be programmed by VW to fit into your ecu - basically if you need one it seems they have you by the short and curly's :evil:
Posted: Thu Nov 01, 2007 7:51 pm
by oscar olop gti
Can't be arsed to start a new thread on this issue, so iam jumping on the end of this one. :)
ABS light has been coming on & off abit over last week or so, can i clean the sensors without removing the discs :?:
Have not got the tools required i.e. the one that pushes the caliper piston
back in.
Any advise :?:
Posted: Thu Nov 01, 2007 9:31 pm
by tegwin
They sell the calliper rewind tool you want for about £12 from halfords....just get one... It will be really usefull for the next time you want to change your pads...
Posted: Sat Nov 10, 2007 3:35 pm
by lmsgti
This site is 100% cursed. My ABS light was on when i had my MOT and it turned out to be the rear sensors.
I had them replaced and the light went off. Two weeks later its back on, although it turns on and off randomly.
Today i noticed that when i went over a speed bump, although slowly, there was a noise and the light came on?
If its ot one thing its another. I love my car but i cant afford to keep it.
Silver
50k
3dr
mint
