Whats the difference between...
Posted: Fri Sep 28, 2007 11:26 pm
by MK6_Motorsport
a 9n pd 100 and a 9n pd 130?
i get the feeling its just electronic differences?
If thats the case then how easy is it to install pd130 stuff onto a pd100?
thanx
dan
Posted: Fri Sep 28, 2007 11:40 pm
by david burton
at least:
1) bigger injectors
2) different turbo
3) different rear lights
4) different engine map
Posted: Sun Sep 30, 2007 9:29 pm
by chris4500uk
Not sure about injectors,
But defnatly a different map, turbo and a front mounted intercooler
Posted: Tue Oct 02, 2007 11:07 am
by DanDiesel
no front mounted intercooler on the 130 engine i can assure you!
Posted: Tue Oct 02, 2007 1:18 pm
by FUTUMSH
6 speed box
Posted: Tue Oct 02, 2007 5:23 pm
by panda
david burton wrote:at least:
1) bigger injectors - Wrong, all PD injectors are the same
2) different turbo - Correct, PD100 is better imo, less lag
3) different rear lights - Yeah, but he's asking about engine stuff!
4) different engine map - Correct again, best bet is just get the PD100 Re-mapped. If you're feeling brave, fit some forge motorsport goodies.
Posted: Tue Oct 02, 2007 7:46 pm
by DAZZA_TDI
panda wrote:david burton wrote:at least:
I beg to differ m8 i`ve had both and the 130 kicks in just as quick
Dazza
Posted: Tue Oct 02, 2007 8:56 pm
by david burton
briskoda say that the injectors are bigger? I don't think you can get a PD100 up to 180bhp with a remap and the turbo.... whereas it's simpler with a PD130....
Posted: Tue Oct 02, 2007 9:03 pm
by david burton
this from another post on here, but I guess you can't believe everything you read
When I looked up the subject a while ago some of the info I found was that the 130/150 hp tdi's have a different turbo to the 100 hp engine. The 130 has a side mounted intercooler like the 100, but the 150 has a front mounted intercooler as standard, The 150/130 has stronger internals (con rods + Pistons i think) plus the injectors are larger, and usually the 130/150's are linked to a 6 speed gearbox.
Along with different ECU, there may be other small differences engine wise.
The only difference between the gt and the sport polo's was the engine, gearbox, seat fabric, silver dash trim, and a perforated leather steering wheel. I nearly bought one when i got my 1.9 sport, but the GT I looked at was not very well specced compared to car I bought.
Posted: Wed Oct 03, 2007 5:23 pm
by panda
we've got our passat running 1 PD150 injector and the rest are PD100. Checked the numbers on the injectors and they are the same. The injector is definately a PD150 as it was removed from an anni mk4 TDI PD150
