need brakes. what to get?
Posted: Mon Oct 22, 2007 2:24 pm
by 1der
im needing new front discs and pads for my car. what does every body recommend /not recommend? thanks for any info
Posted: Mon Oct 22, 2007 2:43 pm
by sorted
Do the 280mm G60 Upgrade, its worth it.
I have EBC green stuff - i think there ok. Not used any other performace names , always had dealer stuff till now.
Posted: Mon Oct 22, 2007 2:46 pm
by MaxZ
Neil, how much is a full conversion for the G60 brakes? Also how quick is it to change everything over?
Posted: Mon Oct 22, 2007 3:07 pm
by sorted
MaxZ wrote:Neil, how much is a full conversion for the G60 brakes? Also how quick is it to change everything over?
You need to get some G60 carries (scrappy cheap cheap) or £100 new from VAG Parts.
This guy has the full setup :
http://www.scottishvag.net/phpBB3/viewt ... 15&t=20600
For the price - 130 is very good. 2*Carriers & Calipers plus the pads and disks (BTW GTI calipers are the same as G60 - so maybe just keep urs)
I dont know the guy on scottish vag - just seen it the other day.
To change the carriers - 2 bolts. While you have the GTi ones of u fit the new disks - so not longer than fitting new disks and pads really.
Posted: Mon Oct 22, 2007 4:01 pm
by Redline
As above, the G60 conversion is very easy to do.
Took me not very long at all, and that included fitting new discs and pads at the same time.
I used the guide from here:
http://forums.clublupo.co.uk/index.php?showtopic=12689
Posted: Mon Oct 22, 2007 4:07 pm
by mk4 glx 1.6
I would recommend the Black Diamond brakes pads, I have been impressed with those since fitting them all round.
Posted: Mon Oct 22, 2007 4:19 pm
by 1der
compared to the standard gti brakes, how much better are the 280mm discs?
Posted: Mon Oct 22, 2007 4:30 pm
by sorted
Cant comment really. Brakes on the GTI when i got it were done, and i done the 280mm with braided hoses straight away.
Posted: Mon Oct 22, 2007 5:37 pm
by Mouse_GTI
They have got to be way better anyway. Standard brakes are a joke, you have to brake 2 years before you get to a corner just to slow down
Posted: Mon Oct 22, 2007 6:46 pm
by Si_GTi
mk4 glx 1.6 wrote:I would recommend the Black Diamond brakes pads, I have been impressed with those since fitting them all round.
Seconded. Superb pads
Posted: Mon Oct 22, 2007 6:51 pm
by ModifiedMadness
What's the biggest disc and caliper combo that'll fit with the standard wheels?
I was wondering if something like this would fit?
Caliper -
http://www.apracing.com/roadcar/caliper ... ily=CP5100
Disc - CP4348-894/5RD, Ø295 x 25mm, Drilled, 30 Vane.
Pad -
http://www.apracing.com/car/brakepad/da ... =CP2340D51
Posted: Mon Oct 22, 2007 7:09 pm
by 1der
whats a good disc to run for the G60 conversion?
Posted: Mon Oct 22, 2007 9:39 pm
by oscar olop gti
I just fitted the standard G60 discs & they are ok. I will fit something like black Diamond or something similar when they need changing.
Posted: Wed Oct 24, 2007 5:46 pm
by h4r1s
So what would i need? (i am assuming the se 16v calipers are the same as gti ones) g60 carriers, pads and discs? will probably give it a go after winter, but just need to find out a price as my discs and pads need changing anyway. oh and will they fit under 14" wheels?
Edit: had a look for g60 discs and they are £280
i am supposed to be looking at the 280mm ones aren't I
+ carriers £100 + pads £80 = a total of £340 from venom motorsport without carriers
Thanks,
Haris
