Hella Adapter Cable
Posted: Sun Jan 20, 2008 7:48 pm
Anyone know a site that sells the hella adapter cable? The cables used to convert the 9n3 rear lights onto the 9n. Thanks
Probably the Worlds greatest Polo resource
https://uk-polos.net/
Yes I sympathise with you on this - it sounds easy but unless you develop the correct knack and use suitably sized/shaped extract tools there is always the possibility of breaking the retainer on a few pins. I fitted a proper VW lane changer convenience kit on my Passat, it involved depopulating one connector and populating a new one - and it certainly tried my patience - in the past at work I've dealt with quite a lot of high density connector pin extraction/refitting.Manni wrote:Yea, I tried, but i cant seem to get the pins out
