mk4 1.4 cl, acceleration hesitation
Posted: Sun Jan 27, 2008 10:35 pm
by gharbud
hi all i have a 1.4 cl, jst recently brought it and having a few problems with it, when accelratiing the car seems to judder through accelration, when the car is in neutral its revs absolutly fine? help
Posted: Mon Jan 28, 2008 10:10 am
by Phatman
Check your ignition parts, especially dizzy cap and rotor arm, then move on to spark plug cables and plugs. I would guess one of these is the culprit.
poor revs
Posted: Tue Jan 29, 2008 6:35 pm
by log
Hi mate just had same prob ended up being spark plugs good luck log
Posted: Tue Jan 29, 2008 10:00 pm
by gharbud
ive changed the spark plugs and checked the dizzy and leads all seems to be fine, its just wen ur accelerating u can feel the car juddering as u accerate but im sure its not mis fring
poor revs
Posted: Wed Jan 30, 2008 6:03 pm
by log
Hi mate like i said last hight my polo same ass yours was doing same it would rev like hell out of gear but put it in gear and it would judder like it was trying to pul pet through .I was told to change h t leads sparks pet filter or temp sender i did all this the plugs was last thing i changed and it hapend to be the plugs giving my polo the same probs ass u got but may be it is one of the others on yours the man who help me was an expert with much experience his name is alex perkins he is prob on line give him a shout hope u r as lucky as i was to replace all parts cost me less than 30 pound alot cheaper than tacking her to v w steelers
Posted: Wed Jan 30, 2008 6:56 pm
by Bepe
stick some injecter cleaner fluid into your fuel tank mate, sounds like your injectors are spluttering
Posted: Mon Feb 04, 2008 5:37 pm
by Fluffmarten
mine sometimes has a similar problem, causes the rev counter to go mental, happened after a recent gearbox, driveshaft and cat change, not too much hassle as it only rarely does it. 1400 miles with the only problems being a dodgy exhaust and taillight wiring. either goin back to a Mk3 or gettin a honda civic
Re: mk4 1.4 cl, acceleration hesitation
Posted: Thu Aug 31, 2017 8:19 am
by kagaraneon
Hi guys.
I experience the same issues.
VW Polo 2002, 1.2, petrol.
Fuel filter was changed, air filter was cleaned...what else can I do?
Alex Perkins can help please?
Posted: Thu Aug 31, 2017 5:45 pm
by alexperkins
Change your spark plugs and if that doesn’t fix it, the three coil packs.
Posted: Thu Aug 31, 2017 8:50 pm
by kagaraneon
Thanks Alex.
I just went last week to the garage.
They said the spark plugs were okay.
One coil was defect and was changed.
Should I still go ahead and change the spark plugs?
Posted: Thu Aug 31, 2017 9:00 pm
by alexperkins
Don’t always trust garages and what they say. If one coil he failed the others are often on their way
Posted: Thu Aug 31, 2017 10:20 pm
by kagaraneon
Thank you again!
How do I check if coil or spark plugs are bad?
Posted: Thu Aug 31, 2017 11:30 pm
by alexperkins
You’d have to look at the spark plugs after they are removed one by one and assess the electrode condition and the color of the tip
Coils are hard to check. It’s normally a case of just replace as there’s only three on your engine
