Indicator Stalks/ Cruise Control
Posted: Tue Feb 19, 2008 7:39 pm
by Hamish
Right. The trip computer switch is a bit sticky so im thinking of replacing the RHS indicator stalk.
Looked in Haynes cant see the answer unless im looking under the wrong section :?
Is tis fairly easy job to do or is it steering wheel off etc etc. A method or any hints and tips would be very usefull.
Also. Are the LHS and RHS stalk units individual or are they one unit as im thinking about retro fitting cruise control 8)
Posted: Tue Feb 19, 2008 8:34 pm
by dino
Both stalks are individual and cruise can be retro fitted (just done it on my Golf)
It is a steering wheel off job to do though.
Posted: Tue Feb 19, 2008 9:08 pm
by Hamish
Thats ghey :(. Cheers for the reply though
Posted: Tue Feb 19, 2008 11:57 pm
by Jeff GTi
is cruise just a plug and play stalk then or does it need setting up with vagcom or similar then?
i assume the process for the 9n and 9n3 would be the same
Posted: Wed Feb 20, 2008 12:13 am
by Hamish
i believe that it takes some setting up on VAGcom
theres a guide here for a Skoda but you need to login
http://www.vagweb.co.uk/forums/about577 ... 845546718b
Posted: Wed Feb 20, 2008 10:51 am
by daa709
Anyone feel like copying that guide over? 8)
Posted: Wed Feb 20, 2008 5:21 pm
by dino
I needed an extra loom on the Golf and it does need activating in VAG-COM
Posted: Wed Feb 20, 2008 6:32 pm
by Hamish
do you know if all models have it on the ecu its just a case of it hasnt been activated?
Posted: Wed Feb 20, 2008 7:42 pm
by dino
Im sure they do as they are all drive by wire (but dont hold me to it!!)
