Passenger side window
Posted: Wed Feb 20, 2008 2:41 am
by Prabz
Ok guys got in the car today and started it up, tried putting passenger window down and it just makes a clicking noise, windows doesnt come down. The driver side is fine, checked passenger window if it stuck but its not, anyone know why ?
Posted: Wed Feb 20, 2008 8:00 am
by Si_GTi
Does it do the same thing no matter which switch you use - the one on the passenger side or the one on the driver's side - if it doesn't matter which switch you press, and it still doesn't go down, it could be the motor? The clicking noise would suggest that the switches are still working.
Posted: Wed Feb 20, 2008 8:05 am
by neilGTI
I agree with Si, its probably the motor, it should be easy to test if you take the door card off.
Posted: Wed Feb 20, 2008 10:28 pm
by Prabz
Well on passenger side it clicks same with driver side, the windows just don't want to come down, thought it was motor
Posted: Thu Feb 21, 2008 8:09 am
by neilGTI
If it is clicking on both switches but nothing is happening, its 95% likely to be the motor.
Try checking all the fuses & *relays first as it could be something simple ?
Also try taking your battery off for about ten minutes then re-connect it to see if that might help.
* I am not sure if the windows use relays, but this could be what is clicking when you press the switches and they do pack up sometimes.
Posted: Thu Feb 21, 2008 12:31 pm
by TheEggShell
Lol...
I've had exactly the same problem recently.
As you say, it doesn't matter which switch you press and there is a clicking noise.
Strangely, mine started working again (after removing half the door to look at the motor :roll: ) so finger crossed yours does the same!
