Page 1 of 2
Standard alloys
Posted: Sun Feb 24, 2008 11:56 am
by yudansha
Hello all
I currently have 17" on my lovely Y reg polo gti ( they were put on by the benny who I bought it off) and I did not get the standard wheels supplied with it.. I would like to take it back to standard size if not a standard alloy.. can anoyone help... did this year roll in on 15"s 4stud?
:oops:
Posted: Sun Feb 24, 2008 2:32 pm
by alexperkins
15x6J 4x100 BBS RX II wheels :D
Posted: Sun Feb 24, 2008 3:08 pm
by jason11
always some on ebay chap
Posted: Sun Feb 24, 2008 3:54 pm
by Tim_GTi
And many car forums, just keep an eye out, chances are they'll need a re-furb though
Posted: Mon Feb 25, 2008 10:27 am
by nogwuy
i still have 1 for sale if you find a set and fancy a spare aswell!! :wink:
Posted: Mon Feb 25, 2008 1:59 pm
by yudansha
jason11 wrote:always some on ebay chap
thanks mate... relying on that tbh :P
Posted: Mon Feb 25, 2008 2:00 pm
by yudansha
nogwuy wrote:i still have 1 for sale if you find a set and fancy a spare aswell!! :wink:
will keep it in mind mate... need to get the first four... ta tho.
Posted: Tue Feb 26, 2008 8:58 pm
by yudansha
I know these arent the standard but would they fit? I have just been offered them and they are quite nice.
Metal Type:
Aluminium
Tyre Type:
All-Weather
Rim Width:
6.5J
Tyre Width:
205
Rim Diameter:
15 inches
Aspect Ratio:
50
Offset:
Load Index:
86
Number of Studs:
4
Speed Rating:
Posted: Tue Feb 26, 2008 9:26 pm
by Tim_GTi
Don't know if a picture was ment to load with that data or not, I didn't get anything.
The tyres seems a little bulky (205/50?), I imagine they'd fit ok on standard suspension, but would appear a bit big, and if you lowered your car you'd get heavy scrubbing
Posted: Wed Feb 27, 2008 6:54 am
by nogwuy
plus your speedo would under-read and your acceleration may suffer a bit :wink:
Posted: Wed Feb 27, 2008 8:24 am
by yudansha
thanks chaps.
will hang on till originals come up or keep looking round the forum
Posted: Wed Feb 27, 2008 9:49 am
by Silky V
I know of someone selling a set.
They may need a refurb though.
I think he wants around £150 for them. The tyres have plently of tread on them as well. PM me and i'll forward you his contact details.
Posted: Wed Feb 27, 2008 1:36 pm
by yudansha
dun! :shock:
Posted: Wed Feb 27, 2008 4:33 pm
by Tim_GTi
nogwuy wrote:plus your speedo would under-read and your acceleration may suffer a bit :wink:
Nah I don't think a tyre change would make that much difference tbh
Posted: Thu Feb 28, 2008 10:04 am
by nogwuy
well if you have a greater wheel diameter due to higher profile tyres, then you are travelling a greater distance for each turn of the wheel. therefore your acceloration will be less and the calculation for your speedo will be out .It will say you are going slower than you are in this case, not very desirable in speed camera infested areas (this effect gets greater the faster you go, e.g. it may be 3mph out when travelling at 30mph, but 7mph out when travelling at 70mph) It depends how many % greater the wheel diameter is from standard as to the error % of the speedo.
But your fuel economy and top speed will be increased in this case :D because at any given engine rpm you will be covering more ground than before (well so long as you are in gear of course :wink:).
I had the opposite effect to this on my mk3 golf gti. i got 16 inch rims to replace the standard 15 inch ones. the original tyres had a profile of 50, but i over compensated for the bigger rims by fitting tyres with a profile of 40 (should have got 45 for the best mach to the original overall diameter) my acceleration was improved, my speedo over-read, fuel economy was down as the speed i was doing at any given rpm was now less. (this was really annoying on motorway driving as the revs were now higher at the same cruising speed, effectivly meaning top speed is reduced)
i changed the wheels again for 17inch rims again with 40 profile tyres, and all was back to as it was before (as the overall diameter was the same as 15 inch rims with 50 profile tyres). i was able to accuratly chech the speedo readings each time as i have a road pilot (camera and accident black spot warning system) which has a gps speedo so i could compare it to the one in the car.
sure all these things are effected to a greater or lesser effect depending on the % differance in the overall diameter of the wheel. But its physics and you cant argue with that. :wink:
