Gearbox, new one, need advice..........
Posted: Mon Mar 10, 2008 10:00 pm
Right, i bought my Polo Gti in July, and love the thing to pieces, however recently the gearbox rapidly deteriorated to a point where the radio wouldnt mask the noise!!!
I Got a Recon box put in by a local company, who sourced a box from A gearbox specialist in Bristol ( i live in Clevedon).
It all went smoothly, got the car back on Saturday, took it for a drive and noticed that the ratios have changed!
The car accelerates quite a bit slower, and 5th gear is 15mph different.
I.e. @ 4000rpm it was around the 80 mark, like any other hatchback.
Now, its 4000rpm at around the 95mph mark (on a private road, accompanied by a variety of saftey vehicles)! This seems odd, and considering that i've heard that only Gti gearboxes fit Gti's, what the hell did they put in it, gears from a diesel???
I phoned up the company saying the above, the gearbox spec is NOT the same, from when i brought it in 3 days earlier...
The guy apparently phoned up the specialist he sourced the gearbox from, and told me that i should run it in for a 1000 miles, and then go back, as i shouldn't be doing 95 with it. The only reason i did that, is to see the actual difference, and as it happens, the 4000rpm marker was one that i remembered!
I fail to see how this can change the amount of teeth on the cogs, and therefore reduce final drive! I understand that the oil being new could be viscous and new, and hinder the acceleration, but i didn't think this would change 5th gear by 15mph!! 4th is longer, but i havent got details on that one....
Can anyone vouch their final drive (5th gear) speed to 4000rpm? If you have no access to a private road
i think it was 3000rpm at 70mph..
i have spoken to others, and they reckon that il get no-where as they'll just say they took the number off the box, and ordered it as per that spec!
Any advice, tips, steps to take would be extremely helpful..
Cheers guys
Laurie
Cheers guys
Laurie
