UK-POLOS.NET - THE VW Polo Forum • steering shaking at 60mph?
Posted: Mon Mar 17, 2008 12:59 am
by Razz
i just changed the wheels on my car to 16" RH's and whenever im driving at around 60-70 the steering starts to shake.. when im driving at around 80 or above.. or 50 n below.. it seems perfectly normal. does anyone kno1 what it can be? anyone had similar problem? thanks.
Posted: Mon Mar 17, 2008 8:03 am
by Mike_M
Wheel balancing needed
Posted: Mon Mar 17, 2008 9:54 am
by Luke'sGti
As above, get your wheels balanced
Posted: Mon Mar 17, 2008 10:33 am
by Razz
i only had my tracking and wheels balanced not long ago.. about 2 weeks ago, but this was on the original gti wheels, so can changing rims make a difference and require wheels balanced?
Posted: Mon Mar 17, 2008 11:03 am
by Luke'sGti
Er yes, everytime you change your wheels/tyres they should be balanced. Balancing wheels is where weights are placed on the Rim (on the inside edge). Hopefully this website can explain it to you better
http://www.familycar.com/CarCare/AlignmentBalance.htm
Hope that helps.
Posted: Mon Mar 17, 2008 12:33 pm
by neilGTI
I had similar problems on my old wheels.
If you still have problems after tracking/wheel alignment, it may mean one of your wheels is buckled, which is what i had :(
Good excuse for me to get new wheels though :lol:
Posted: Mon Mar 17, 2008 12:51 pm
by Razz
thanks for that luke
understand it a bit better now :D it seems like the symptoms are of wheel balancing, so i shall be getting that done soon
i dont have spigit rings on though right now, not sure if i should get them done before i put them on?
car is in the garage today though for diagnosis, doesnt seem to start sometimes :( think it might be the temperature sensor playing up
lol good excuse for new wheels neil, what wheels are you running now then?
Posted: Mon Mar 17, 2008 4:33 pm
by neilGTI
I have got some lenso BSX wheels now:
Much better than the old wheels and i can go over 70 without worrying about the "shakes" :D
Posted: Tue Mar 18, 2008 10:45 pm
by Razz
they look lovely m8, quite similar to the bbs rms!
Posted: Tue Mar 18, 2008 11:05 pm
by Redline
Razz wrote:i dont have spigit rings on though right now, not sure if i should get them done before i put them on?
Do the new wheels you've got need spigot rings?
If they do and you're running without them, that would cause problems such as shaking and vibration.
Posted: Wed Mar 19, 2008 12:12 pm
by Razz
yeah the new wheels do require spigot rings, so i guess that could have an effect on the shaking aswell?
il need to order some spigot rings in, if not then get my wheels balanced[/quote]
Posted: Wed Mar 19, 2008 3:29 pm
by Redline
Yeah that's the best way of doing it.
Get the spigot rings on, and if it's still doing it then look at balancing.
