I know this sounds stupid
Posted: Tue Feb 10, 2004 1:58 pm
by blackmk3
am i able to cut off my aerial so it is about half the length and still receive the same signal, or does that just f**k it up?
Posted: Tue Feb 10, 2004 2:00 pm
by DanW
would have thought it would have been ok, might loose a bit of signal from time to time. I never put my ariel up.
Posted: Tue Feb 10, 2004 2:03 pm
by blackmk3
i need a definate answer you see, because if " it should be ok" was not ok then i need a new aerial. Are you sure? or know anyone who would be?
Posted: Tue Feb 10, 2004 2:37 pm
by LogIK
Half extend your ariel and drive around to see what kind of reception you get. If it is fine, then cut it down if you really want.
I only extend mine a bit and I get perfect reception.
by DanW
you've done it? Turn the radio on if u get a good enough signal then your OK. I know a MK5 without an ariel on it at all, u can always get a dab one, which replaces the standard ariel with a metal block that sticks on to the wind screen, it's dead small too.
Posted: Mon Feb 16, 2004 5:32 pm
by Tahrey1043
Forgive me for sounding like a tosser, but why don't you just pull it only half way up? Why bother cutting it to bits?
Posted: Mon Feb 16, 2004 5:44 pm
by DanW
Tahrey1043 wrote:Forgive me for sounding like a tosser, but why don't you just pull it only half way up? Why bother cutting it to bits?
lol, or just leave the freaking thing down. I never put mine up! and get proper good reception!
Posted: Mon Feb 16, 2004 6:18 pm
by Krupa
Do you have an aerial like I had on mine when I got it? About 2 1/2 foot long and can't be retracted?
If so, just lose it and get a replacement one from Halfords. They can be left retracted.
Or even better get a beesting - the reception with them is amazing!
Posted: Fri Feb 27, 2004 3:42 am
by Tahrey1043
oh the irony, i rip into someone for asking dumb questions about aerials and now i have to do the same
i've got a funny buzzing noise interfering with some FM broadcasts of late, suggestive of major EM interference from the ignition (worst at idle, "splatchy", tone goes up and fades slowly as revs climb). last time i ever really noticed this was trying to get AM with the aerial down - nightmare. but this is FM, with the aerial up, and it's only come on in the last week. is it current leakage from cables/plugs/dizzy/coil, a knackered aerial, or what?
might yet have to get a beesting
Posted: Fri Feb 27, 2004 12:03 pm
by DanW
anything come loose like an earth cabel?
Posted: Wed Mar 10, 2004 7:26 pm
by Tahrey1043
hmmm, true, i might have fried some small earth connection with my frequent cycle of "run the battery flat - jump start - scoot around keeping the revs over 3000 for an hour"...
gonna be a nightmare to check them all though! hope it's just the aerial cable being loose at the back of the stereo (will have to find my removal tools before i can check that tho!)
Posted: Wed Mar 10, 2004 7:35 pm
by ereeiz
try a suppressor from halfords, or just use a resistor on the starter or something, see mateymatey.com its on the left hand side of the homepage I think
Posted: Wed Mar 17, 2004 2:18 am
by Tahrey1043
On the starter?
It's not really so much of a problem on starting, seeing as the radio blinks off and all til you release the key...
(As I am a lazy arse, I only today got round to checking the oil (needed MORE than a litre to get back close to the top line...) let alone the aerial connector, but then I haven't used the radio much - getting the new tape adaptor was "
